Air conditioning on passenger side only | 2014 LE - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 11th Gen (Sedan 2014-2019)/Scion iM (2016-2018) Forums dedicated to the 11th generation Toyota Corolla, as well as the directly related Scion iM
post #1 of 7 Old 06-09-2019, 07:35 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
New here, did a quick search but didn't find a solution. I have a 2014 LE that the AC will only blow cold on the passenger side. I have tried all combinations of vent sections and cant get it cold on any of the driver side vents. Even with AC on high, it still blows warm air, but the passenger side is cold like its supposed to be. Could this be a blend door issue? I have tried to locate one on the drivers side but I cannot find it. Does anyone have any ideas as to what could cause this? It seems odd since the car doesn't and didn't have dual climate zones, until now.
htbracy is offline
post #2 of 7 Old 06-10-2019, 08:02 AM
Senior TN Member
Quoted: 395 Post(s)
No dual-zone indeed. From what you say, I can't be sure if you tested all other vents possible combinations separately ("def" only, dash only, floor only - including under the seat) to see if there could be a duct problem but it's unlikely, since you mention it does blow, only with warm air. It may seem counter-intuitive since you get come cold air somewhere but two basics may still be the culprit : clogged cabin filter or system low on refrigerant for some reason.
jolly is offline
post #3 of 7 Old 06-10-2019, 10:29 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
The cabin air filter was replaced. That was much needed. It did help airflow but the temp didn't change.
htbracy is offline
post #4 of 7 Old 06-12-2019, 06:14 AM
Quoted: 1 Post(s)
You need 4-60 air conditioning!
4 windows down, 60 MPH!
Mikev0882 is offline
post #5 of 7 Old 06-12-2019, 04:26 PM
Senior TN Member
Quoted: 395 Post(s)
That leave checking the refrigerant level of the system.
jolly is offline
post #6 of 7 Old 06-12-2019, 10:39 PM
Moderator
75aces's Avatar
Quoted: 987 Post(s)
Clogged heater core.
In the garage,
9th Gen Corolla XRS
2012 Mazda 5
"If it ain't broke yet, it's probably still working like a Swiss time piece; until you open it up and all hell breaks loose"
75aces is online now
post #7 of 7 Old 06-13-2019, 12:33 AM
Got Pyro?
funman1's Avatar
Quoted: 816 Post(s)
clogged heater would not cause this...
I'm guessing it's low on R134 lately the way Toyota has been designing the evap systems.
Instead of going horizontal and then up and down They go vertical from right to left.
So when it starts to get low one side is colder than the other.
Professional Pyro..
No really; I get paid to blow stuff up...
funman1 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 11th Gen (Sedan 2014-2019)/Scion iM (2016-2018)
User Tag List
Linear Mode Linear Mode
