A/C compressor - oil - Toyota Nation Forum : Toyota Car and Truck Forums
alt.autos.toyota.camry Toyota Camry discussion newsgroup.
post #1 of 9 Old 09-21-2006, 04:47 PM
Pszemol
Guest
Posts: n/a
Quoted: Post(s)
If I get a a/c compressor from an unknown source
like a junkyard, how do I check how much oil is
there left and how much to add before installation?
Is there a way to remove all oil to empty this thing?
This way I can add specified amount from scratch.
post #2 of 9 Old 09-23-2006, 01:39 AM
sqdancerLynn
Guest
Posts: n/a
Quoted: Post(s)
Re: A/C compressor - oil
I would NOT buy a used compressor... Their is more to fixing it than just
changing the compressor. Assuming the old compressor seized ??
blew up. The system needs to be flushed VERY GOOD
and a new dryer installed, & need to check for leaks. Then you need to
evacuate the system (you have a vacuum pump?) Then you need to recharge to
the proper pressures (you have a set of gauges?)
post #3 of 9 Old 09-23-2006, 10:17 AM
Pszemol
Guest
Posts: n/a
Quoted: Post(s)
"sqdancerLynn" <[email protected]> wrote in message news:[email protected][color=blue]
> just changing the compressor. Assuming the old compressor seized ??
> recharge to the proper pressures (you have a set of gauges?)[/color]
My old compressor did not blew up. It is perfectly fine, except
it has a damage on the clutch bearing support causing the clutch
to malfunction. I tried to replace clutch alone but discovered
that the problem is with the compressor, not only the clutch.
That is why I need to replace the compressor.
So, since my compressor did not seize my system does not need
flushing, right ?
And yes, I have a set of gauges and I have access to a vacuum pump.
Why wouldn't you buy a used compressor ?
Can you answer to my original question about the amount of oil ?
post #4 of 9 Old 09-24-2006, 07:55 AM
Guest
Posts: n/a
Quoted: Post(s)
"Pszemol" <[email protected]> wrote in message
> flushing, right ?
> Can you answer to my original question about the amount of oil ?[/color]
You can get essentially all the lubricant out of the compressor by draining
it
properly, and start off with a fresh charge. You can't conveniently guess
or
estimate how much lubricant is left in a system especially if there has been
a leak.
I just had my Reatta converted from R12 to R134a because (1) R12 is too hard
to
access around here and (2) because I had a leak and needed to replace the
compressor
for that reason. Decided to start afresh.
The local mechanic flushed the system (because you have to do so when
changing
refrigerant types and therefore lubricant types) and found it full of 'black
death'.
If you dont do AC jobs correctly from the start, you are likely to lose a
good deal of
money and be irritated at the result.
There is a lot of good information at [url]www.ackits.com[/url] and also in the
associated
forum.
post #5 of 9 Old 09-24-2006, 01:10 PM
Pszemol
Guest
Posts: n/a
Quoted: Post(s)
<[email protected]> wrote in message news:[email protected][color=blue][color=green]
>> flushing, right ?
> by draining it properly, and start off with a fresh charge.[/color]
What does it mean exactly "drain it properly"?
How to drain it properly ?
[color=blue]
> You can't conveniently guess or estimate how much lubricant
> is left in a system especially if there has been a leak.[/color]
Understandable.
[color=blue]
> and also in the associated forum.[/color]
Thanks.
post #6 of 9 Old 09-24-2006, 11:42 PM
sqdancerLynn
Guest
Posts: n/a
Quoted: Post(s)
Buying a used compressor is buying someone else's
problems. Esp when you find it blowing up in a month or two because their
was dirt in it from impropper handeling. . & you have to do the whole job
over
post #7 of 9 Old 09-25-2006, 10:09 AM
Pszemol
Guest
Posts: n/a
Quoted: Post(s)
> over[/color]
I took it from the engine on the junkyard myself.
Tell me please, what is "improper handling" - I will know how it was handled :-)
post #8 of 9 Old 09-25-2006, 01:39 PM
Guest
Posts: n/a
Quoted: Post(s)
[email][email protected][/email] wrote:[color=blue]
> news:[email protected][color=green]
> > flushing, right ?
> it
> or
> a leak.
> to
> compressor
> changing
> death'.[/color]
'black death' ?
Is this a typical problem with camrys, '96 and newer?
post #9 of 9 Old 09-25-2006, 05:28 PM
Quoted: 2 Post(s)
The link below explains black death.
[url]http://reviews.ebay.com/Frequently-Asked-Auto-A-C-Questions-Part-1_W0QQugidZ10000000000932436?ssPageName=BUYGD:CAT:-1:LISTINGS:1[/url]
Can’t find the exact info for you. The oil should just drain out of the compressor. Refill with the same amount that drained out. The A/C system will have lubricant spread out through it.
Best to also replace the dryer also at this time.
Check the link below to find the service manual this car.
[url]http://oregonstate.edu/~tongt/camry[/url]
Vacuum (the longer the better, some shops run overnight), refill the system and see what happens. You should be OK.
toyomoho is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.camry
User Tag List
Linear Mode Linear Mode
BB code is Off
Smilies are Off
[IMG] code is Off
