1995 Camry cruise control - Toyota Nation Forum : Toyota Car and Truck Forums
alt.autos.toyota.camry Toyota Camry discussion newsgroup.
post #1 of 4 Old 10-03-2006, 04:40 PM
RD
Guest
Posts: n/a
Quoted: Post(s)
The cruise control will not set and hold the speed setting.
When I turn on the control the dash light comes on. However, when
setting speed it flashes about 5 times but does not set speed. Is this
a code? The light then stays on but will not flash again until the car
is restarted.
post #2 of 4 Old 10-03-2006, 09:50 PM
Daniel
Guest
Posts: n/a
Quoted: Post(s)
Re: 1995 Camry cruise control
RD wrote:[color=blue]
> is restarted.[/color]
Check the obvious first - binding cables or sticking linkage, poor
connections at the wiring connectors, if it turns out to be the
magnetic clutch inside the unit, or the electronic control, parts can
be expensive.
I didn't find any codes for the cruise control, but that is not normal
behaviour - it's telling you there's a problem with the system. Not
sure what codes would reveal in any event, there aren't multiple
solenoids or sensors, just the single unit.
If it's not something obvious, try finding one used. There were lots of
that year Camry sold, and the cruise control is generally reliable.
post #3 of 4 Old 10-03-2006, 09:55 PM
Quoted: 2 Post(s)
Yes, the light will flash 5-times if there is a problem. A trouble code should be stored in memory. Go to the link below and find the service manual for this year car. The manual will have instructions to access the code and what the problem might be.
[url]http://oregonstate.edu/~tongt/camry[/url]
toyomoho is offline
post #4 of 4 Old 10-04-2006, 11:43 AM
RD
Guest
Posts: n/a
Quoted: Post(s)
Thanks for the information. I expect it will be helpful.
RD
toyomoho wrote:[color=blue]
> toyomoho
> toyomoho's Profile: [url]https://www.toyotanation.com/forum/member.php?userid=59151[/url]
> View this thread: [url]https://www.toyotanation.com/forum/showthread.php?t=158530[/url][/color]
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.camry
User Tag List
Linear Mode Linear Mode
BB code is Off
Smilies are Off
[IMG] code is Off
