P0500 Code - 2.7 5 spd - Speedo Issue - Toyota Nation Forum : Toyota Car and Truck Forums
T-100 Forum Discussion forum for the short-lived but extremely popular Toyota T-100 model.
 2Likes
post #1 of 23 Old 08-01-2014, 02:10 PM Thread Starter
tmgrdon's Avatar
Quoted: 3 Post(s)
(Thread Starter)
Howdy folks,
Truck - 1997 T100 2.7L 5 spd - 2wd - 190k
So my speedo never really worked right on the truck, bounced around if I gave it more throttle it would visibly slip etc..
Finally it went kaput, the odometer worked for a while then that quit too (well reads about a mile per 100-200 miles currently).
Anyhow I have the P0500 code and wanted to repair it.
I removed the speedo gear from the trans. I tested it out spinning and it moved the speedo gauge no problem. The teeth were very worn and inconsistent on it so it seemed to be a no brainer and I ordered a new one.
Replaced it with the Toyota part, tested it prior to install and it moved the speedo gauge no problem. So I installed it. Upon driving no reading on the speedometer still.
So I drained a damn quart of trans fluid, removed it again and tested it again. It moves the speedo. Then I learned there is a VSS sensor behind the dash that might be a culprit so I tested the gear with the ignition on and this time with a power drill to get it up to 25mph. Works just fine with ignition on.
Only time it wont work is when seated into the transmission. What the hell? I have inspected the interior gear that the speedo cable connects to and it looks fine. I cannot view it spinning as I'd need the cable out and the vehicle moving and I'm a one man show and don't feel safe doing that.
Any ideas? Is testing this with the ignition on not good enough? The mechanical side seems to be working properly except for if it isn't seated properly internally to the trans. But if the gauge reads with the ignition on is that good enough or what? I am so lost.
tmgrdon is offline
post #2 of 23 Old 08-01-2014, 04:18 PM Thread Starter
tmgrdon's Avatar
Quoted: 3 Post(s)
(Thread Starter)
Update.
Pulled instrument cluster.
Vehicle is on jack stands to raise rear axle.
Ran car in 1st with speedo hooked up and there is no movement at the instrument end. Since I've confirmed it works and reads when operated by hand or power drill I guess we can pretty much asses that for whatever reason the speedo gear is not seating to the internal gear in the trans to allow it to get a reading. Why, I have no idea.
Not the best news that the issue is with an internal gear on the trans though...
tmgrdon is offline
post #3 of 23 Old 08-01-2014, 04:41 PM Thread Starter
tmgrdon's Avatar
Quoted: 3 Post(s)
(Thread Starter)
Update.
Put car in 1st, let it idle and took a look under the truck. The internal gear is spinning.
So... for some reason, the internal gear is not seating to the speedo gear. I have no idea why, I really don't know what do to but that connection is the failure. Its a brand new speedo gear, internal gear looks undamaged. There is really only one way to fit the speedo drive into the trans, straight in and secured with a bolt.
WTF
tmgrdon is offline
post #4 of 23 Old 08-01-2014, 08:52 PM
jabush's Avatar
Quoted: 36 Post(s)
First off...welcome to the T100 board!
Secondly, it appears that you've confirmed that the speedo gear, cable, etc.. is working fine. The po500 code could be a couple other things beside the speedo cable/gear itself, including a short in the #1 Vehicle Speed Sensor circuit, the #1 VSS itself or a problem with the ECU. It threw a code because the ECU detected a problem. Did you notice any frayed or damaged wires when you removed the cluster? How about under the hood? Do all your other gauges & dash lights work? Any other issues with (dash) lights? Have you checked/cleaned your grounds? The fact that the speedo never really worked correctly screams electrical issue (to me anyway).
This probably hasn't been a whole lot of help, but it starts somewhere, and you did find the best T100 board in existence. Hopefully someone else will chime in that has had this problem or knows more than me. Keep posting as you work through this issue.
Again...welcome aboard.
1996 T-100 Long Bed, 5 Speed, 2WD
2002 Ford F-150 Lightning
jabush is offline
post #5 of 23 Old 08-01-2014, 09:17 PM Thread Starter
tmgrdon's Avatar
Quoted: 3 Post(s)
(Thread Starter)
Thank you for responding, out of two toyota forums you are the first to let me know I'm not speaking to myself.
I don't see this being an electric issue. When installed the gear is not making contact with the internal gear as it is not turning the speedometer cable inside the cab. So it can't drive the speedometer even if it wanted to.
My big issue is what the hell has caused this gear to be unable to be seated inside the transmission.
I can turn it freely when installed into the transmission. WTF? Its the correct part, was an IDENTICAL match to the part removed. Why is it not working?
tmgrdon is offline
post #6 of 23 Old 08-01-2014, 09:38 PM
jabush's Avatar
Quoted: 36 Post(s)
Question
OK, did some poking around. I did see a post where a guy got the po500 code and fixed it by topping off his tranny fluid while the vehicle was hot. I'm assuming you have an auto. How's the fluid level? The inner gear may need adequate fluid/pressure to engage the speedo??
jabush is offline
post #7 of 23 Old 08-01-2014, 09:59 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 892 Post(s)
Sounds like the cable might be bad or stripped out on the connecting side to the transmission gear. Snap some piccies of the parts and post them.
I don't believe you've replaced the speedometer cable yet, correct?
The gear that drives the speedometer gear should be pinned/keyed on the output shaft. You'd have to disconnect the tail shaft to look and see if it's still in place. It's possible that it's been sheared and there's just enough friction to drive the gear without any load but not when the cable is hooked up to it. Might be worth it to pull the tail shaft and take a peek.
Have you tested the speedometer gear with something like a toothpick in the slot and see if you can stop the gear from moving while the transmission is in gear?
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, dual oil catch jars, AC mod, aero cap, lower aero package, 67% grill block, aero single wheel trailer
BamZipPow is online now
post #8 of 23 Old 08-01-2014, 10:15 PM Thread Starter
tmgrdon's Avatar
Quoted: 3 Post(s)
(Thread Starter)
I have taken a power drill to the speedometer cable, then put my phone on video mode watching it.
Ran drill, speedo goes right up to 25mph. The cable is not broken.
So I think I have it figured out.
The transmission is painted gray. It MUST be a rebuild. I took a closer look at the old speedo gear and the new one and they are a different size. Same length, same markings same everything but one is a few mm's wider and that is the old one.
I ordered the new part for my model year, maybe this rebuilt trans is from an older model with a different size speedo gear.
New one that doesn't work has an 11 - 29 marking on the cog, old one 11-27
So.. guess I have a transmission from an older model in my truck... anyone know how to find out what year?
tmgrdon is offline
post #9 of 23 Old 08-01-2014, 10:50 PM
BamZipPow's Avatar
Quoted: 892 Post(s)
11:29 should be the correct one. Part number should be 33403-39245. The 29 designates the number of teeth. So the 29 tooth gear should be wider than the 27 tooth gear because there are more teeth and it needs to turn slower, no?
The auto speedometer gears are the 6x series. 2WD and 4WD speedo gears are not supposed to be interchangeable but I don't know that fer a fact.
11:30 is what goes into the 4WD. Part number is 33403-29105.
Here's a thread that sheds some light on the various speedo gears.
http://www.soarerworld.com/forum/sho...496#post241496
Matching up the 11:27 speedo gear...that would make it a RN80 frame. Isn't that a Toyota pickup frame?
post #10 of 23 Old 08-01-2014, 10:54 PM Thread Starter
tmgrdon's Avatar
Quoted: 3 Post(s)
(Thread Starter)
Maybe but the 29's not making contact. I've eliminated all other variables, and this is a rebuilt transmission. They don't come painted grey from the factory.
tmgrdon is offline
post #11 of 23 Old 08-01-2014, 11:01 PM
BamZipPow's Avatar
Quoted: 892 Post(s)
Yer T-100 is supposed to have the W59 transmission which was bolted up to a 2rzfe or 3rzfe engine.
http://en.wikipedia.org/wiki/Toyota_W_transmission
It's possible that the W59 transmission you have could've come from a Tacoma or 4Runner 2WD or 4WD.
My 1996 T-100 2.7L long bed is an auto...so no help there.
post #12 of 23 Old 08-01-2014, 11:05 PM
BamZipPow's Avatar
Quoted: 892 Post(s)
Can you tell if the metal driving gear in the transmission is scalloped out? It shouldn't be since the speedometer gear is plastic and would probably wear before the driving gear would.
post #13 of 23 Old 08-01-2014, 11:07 PM Thread Starter
tmgrdon's Avatar
Quoted: 3 Post(s)
(Thread Starter)
So what models took the 11-27 gear?
It worked before it wore out and the 29
Isn't so I'm stuck here what would you do?
Probably find a 11-27 gear
tmgrdon is offline
post #14 of 23 Old 08-01-2014, 11:34 PM
BamZipPow's Avatar
Quoted: 892 Post(s)
Wink
In case you want to replace the transmission with a used one, here's the listing from www.car-part.com. It will give you an idea of what you can expect fer a used transmission.
Year
Part
Model Description Miles Part
Grade Stock# US
Price Dealer Info
1996
Transmission
Toyota T100 0 A WAP01149 $1526.46 WeaverParts.com USA-GA(College-Park) E-mail 877-809-8072 /678-783-1433
1996
Transmission
Toyota T100 138,000 A WAP04867 $1526.46 WeaverParts.com USA-NC(Monroe) Request_Quote 888-959-3231 / 704-261-0102 Request_Insurance_Quote
1996
Transmission
Toyota T100 5SPD 2.7L 0 A 136164 $1200 Brandywine Automotive Centers USA-MD(Brandywine) Request_Quote 1-866-214-2175 Request_Insurance_Quote
1996
Transmission
Toyota T100 5SPD 2.7L 0 A 136164 $1200 Eden Auto Parts - Yard #13 USA-MD(Eden) Request_Quote 1-866-214-2175 Request_Insurance_Quote
1996
Transmission
Toyota T100 4X4 STOCK# 001590-46820 46,000 1590 $1000 Action Auto Parts & Glass (Alaska) USA-AK(Fairbanks) E-mail 1-907-456-1818
1996
Transmission
Toyota T100 196,000 A GMA190 $750 Staunton Wrecking Yard USA-VA(Staunton) E-mail 1-800-476-5970
1997
Transmission
Toyota T100 $750 Global Auto Parts USA-MI(Detroit) E-mail 1-313-866-8888
1997
Transmission
Toyota T100 2.7 2WD 5 SPEED REBUILT REB $750 Rancho Toyota Recycling RCAR Member USA-CA(Rancho-Cordova) Request_Quote 877-551-5575 / 916-631-7777 Request_Insurance_Quote
1996
Transmission
Toyota T100 STD,2.7,5 Sp,RWD,TD 20296 $750 Wheeler Auto Parts - ARAPro USA-VA(Fredericksburg) Request_Quote 540-693-1028 Request_Insurance_Quote
1996
Transmission
Toyota T100 2.7,5SPD 65766 $750 Friendly Trucks Inc. USA-MD(Accokeek) Request_Quote 301-283-0100 / 800-870-8191 Request_Insurance_Quote
1996
Transmission
Toyota T100 2.7IC,5 Sp,-ABS,W59,NTS 81,614 A H10165 $675 Felton's Auto Parts USA-WA(Snohomish) E-mail 800-713-3999 / 360-563-9315
1996
Transmission
Toyota T100 4CLY, MT 47,998 A 0C0225 $650 Sun Auto & Salvage USA-ME(Norridgewock) E-mail 1-207-474-5176/1-800-843-5176
1996
Transmission
Toyota T100 4CYC,5SP,,STOCK NO. #C376.0 #C376.0 $650 M & J Auto Salvage USA-TN(Chattanooga) E-mail 1-423-867-8009 / 1-888-558-8009
1996
Transmission
Toyota T100 30 DAY WARRANTY IF INSTALLED BY CERTIFIED TECHNICIAN OR BUSINESS. 1342 $650 Morgan Automotive USA-GA(Hortense) E-mail 1-912-778-4055
1995
Transmission
Toyota T100 used 154,000 A 00001175 $600 Elite Auto Parts USA-AZ(Phoenix) E-mail 602-276-4400
1997
Transmission
Toyota T100 2.7L,5 Sp,RWD,Delay,airbag,Floor 180,797 A 130129 $600 Paul's Pick-a-Part USA-ME(Chelsea) E-mail 207-582-7460
Transmission
5SPD,8-94 453430 $575.08 B & R Auto Wrecking, Eugene USA-OR(Eugene) Request_Quote 800-234-0098/541-726-7778 Request_Insurance_Quote
1994
Transmission
Toyota T100 2.7L,5MT,RWD,05/94,MT, 4 CYL-- 250,000 C I1048J $550.01 M and J Auto Recycling USA-CT(Colchester) Request_Quote 1-800-962-0281 Request_Insurance_Quote
1996
Transmission
Toyota T100 30 DAY WARRANTY 858071 $550 Kings Auto Parts USA-MD(Port-Deposit) Request_Quote 1-800-559-6483 Request_Insurance_Quote
1997
Transmission
Toyota T100 -200K 200,000 A 12-525 $550 One Stop Auto Wreckers USA-OR(Klamath-Falls) Request_Quote 1-800-452-1304 Request_Insurance_Quote
1997
Transmission
Toyota T100 MT, 4 Cyl, INSPECTED, GOOD USED, 6 MONTHS WARRANTY, MUST GET EXCHANGE 1,000 A B60069 $550 Sierra's Trucks USA-CA(San-Bernardino) Request_Quote 909-383-7155 Request_Insurance_Quote
1995
Transmission
Toyota T100 REBUILT 180 DAYS WARRANTY 0121 $550 Japanese Truck Dismantling USA-CA(Wilmington) Request_Quote 310-835-3100 Request_Insurance_Quote
1996
Transmission
Toyota T100 160,500 A SME134 $544.5 MARS Auto and Truck Parts USA-OH(Mogadore) Request_Quote 1-866-321-MARS (6277) Request_Insurance_Quote
1996
Transmission
Toyota T100 BLUE EXT,5/96,REG CAB,2.7L,MANUAL TRANS,180K 180,000 A T573 $500 Harry A. Wright's Inc. VARA USA-VA(Charlottesville) Request_Quote 1-800-727-7574 Request_Insurance_Quote
1996
Transmission
Toyota T100 RWD,2.7L,5SPD 162,953 A 213837 $500 Shipman Auto Parts, Inc. USA-MN(Brainerd) E-mail 1-800-892-4779
1995
Transmission
Toyota T100 3-95,RWD,2.7,SD,FLR RC1206 $500 Rick's Auto Part of Dillion LLC USA-SC(Dillon) E-mail 888-774-7989 / 843-774-7989
1995
Transmission
Toyota T100 4X2,5SP $500 Brothers Imports, Inc. USA-UT(Chester) E-mail 801-577-8368 / 435-436-5225
1995
Transmission
Toyota T100 2DR,WHI,12-94,2.7,GOOD N09 192,000 A MJ5036 $500 Blue & Gold USA-SC(Goose-Creek) Request_Quote 843-797-5580 / 800-331-1353 Request_Insurance_Quote
1995
Transmission
Toyota T100 MT 4X2 4 CYL-133000 N $500 McKee Wrecker & Salvage Inc USA-FL(Middleburg) Request_Quote 904-282-0058 / 904-282-5170 Request_Insurance_Quote
1996
Transmission
Toyota T100 REBUILT 1652 $500 Auto Recycling of Wilmington USA-CA(Wilmington) Request_Quote 310-834-7583 Request_Insurance_Quote
1994
Transmission
Toyota T100 T-100,3RZFE,5 Sp,RWD,DELAY,RADIO,Flo, Prod Date = 06/30/04 T4398 $475.13 Baker Truck Parts USA-SC(Greenville) Request_Quote 877-266-2676 / 864-277-9479 Request_Insurance_Quote
1996
Transmission
Toyota T100 155,063 A VA4327 $450 Virginia Auto and Truck Parts USA-VA(King-George) Request_Quote 800-390-2025/540-775-5004 Request_Insurance_Quote
1995
Transmission
Toyota T100 M.T., 4 cyl,MANUAL TRANS TRV1031 $450 Auto Salvage Company, Inc. USA-SC(Ladson) Request_Quote 1-877-999-1995 Request_Insurance_Quote
1995
Transmission
Toyota T100 5SP,9/94 TRV724 $450 Auto Salvage Company, Inc. USA-SC(Ladson) Request_Quote 1-877-999-1995 Request_Insurance_Quote
1996
Transmission
Toyota T100 M.T., 4 cyl,1 Year warranty, watch this vehicle on YouTube at
sAq1WKwRew 271,000 C 14080 $450 Fresno TAP Recycling USA-CA(Fresno) Request_Quote 1-559-268-7100 Request_Insurance_Quote
1994
Transmission
Toyota T100 114,428 A XDT131 $450 Knik Towing & Wrecking (Alaska) USA-AK(Wasilla) E-mail 1-907-376-2584
1996
Transmission
Toyota T100 2.7l,5 Sp,RWD,CD,Floor 215,153 C 130367 $450 Wheeley Auto Mall USA-NC(Graham) E-mail 1-336-376-6006 / 1-877-724-6885
1994
Transmission
Toyota T100 5 SPD 9,000 A 3H029 $450 Mini Truck Dismantling - SCADA USA-CA(San-Diego) E-mail 619-233-3884 / 800-827-1970
1997
Transmission
Toyota T100 $450 Alfred's Auto USA-CA(Sun-Valley) Request_Quote 818-768-1212 Request_Insurance_Quote
1994
Transmission
Toyota T100 7 month warranty, GLD-BRO Prod Date: 07/01/1994-167K 167,000 1MI3777 $440 Johnson Auto Recycling USA-NC(Asheville) Request_Quote 1-800-222-0815 Request_Insurance_Quote
1996
Transmission
Toyota T100 MT, 4CYL TESTED/GOOD 156,423 A TNN1069 $400 Timo's Auto Wrecking, LLC USA-CA(Arroyo-Grande) Request_Quote 1-805-343-7747 Request_Insurance_Quote
1997
Transmission
Toyota T100 WHT,SE,2.7L,5 Sp,RWD,Tilt,Floor 188,600 A P14083 $400 Premium Auto Parts, Inc. USA-UT(Salt-Lake City) E-mail 1-866-582-2622
1995
Transmission
Toyota T100 4 CYL MANUAL 400U $400 Blountville Auto Salvage USA-TN(Blountville) Request_Quote 1-423-323-5940/1-800-443-9182 Request_Insurance_Quote
1995
Transmission
Toyota T100 $400 Clayton's Auto Parts, Inc. USA-VA(Carrollton) Request_Quote 1-757-238-2885 Request_Insurance_Quote
1995
Transmission
1995
Transmission
Toyota T100 -86K 86,000 A ITT16 $400 Rio Grande Auto Parts USA-TX(El-Paso) Request_Quote 915-584-2531 / 877-584-2531 Request_Insurance_Quote
1994
Transmission
Toyota T100 2.7L,MANUAL TRANS 127,000 A 2166 $400 Auto Recycling of Wilmington USA-CA(Wilmington) Request_Quote 310-834-7583 Request_Insurance_Quote
1995
Transmission
Toyota T100 60111339 $375 Flat Rock Auto Parts and Salvage USA-TN(Murfreesboro) Request_Quote 615-849-8247 Request_Insurance_Quote
1996
Transmission
Toyota T100 2.7L,MANUAL TRANS-361K 361,000 C 1144 $375 TowMasters USA-LA(Bossier-City) Request_Quote 318-747-7114 / 877-748-7121 Request_Insurance_Quote
1994
Transmission
Toyota T100 2.7,5 SP,2WD, 068857 $360 Dutcher's, Inc. USA-NY(Morrisville) E-mail 1-800-395-9999 1-315-684-9212
1995
Transmission
Toyota T100 5SP,2.7 HD2914 $350 A & G Auto Recycling USA-OR(Creswell) E-mail 541-942-9067
1995
Transmission
Toyota T100 5MT,2.7,2WD,NOTE JA5827 $350 A & G Auto Recycling USA-OR(Creswell) E-mail 541-942-9067
1996
Transmission
Toyota T100 READY,182K-182K 182,000 A E05001 $350 Turnpike Auto Parts USA-NH(New-Ipswich) Request_Quote 1-603-878-1500 Request_Insurance_Quote
1997
Transmission
Toyota T100 4CY-5SPEED-RUNS VERY GOOD 910532 $350 J.C. Auto Dismantlers USA-CA(San-Jose) Request_Quote 1-800-860-6606 / 1-408-287-5853 Request_Insurance_Quote
1994
Transmission
Toyota T100 REBULTE 180 DAYS WARRANTY 5 SPEED $350 All Japanese Auto Dismantling (All Toyota) USA-CA(Los-Angeles) E-mail 323-564-7900 / 323-249-5000
1994
Transmission
Toyota T100 MT, 4 Cyl B0031 $350 Gates Salvage, Inc. USA-VT(Hardwick) Request_Quote 802-472-5058 Request_Insurance_Quote
1995
Transmission
Toyota T100 MT, 4 Cyl 175,000 A 14G1192 $300 U Pick U Save - Gardena USA-CA(Gardena) Request_Quote 310-327-0400 Request_Insurance_Quote
1995
Transmission
3RZ,5SP,FL,CASE BROKEN 68,000 A 8G1680 $250 ***an Auto Parts USA-AL(Piedmont) E-mail 1-800-331-5282
1995
Transmission
2.7,5SPD,FL,2WD PULL CK CLOSE 28,000 A 9A1973 $250 ***an Auto Parts USA-AL(Piedmont) E-mail 1-800-331-5282
1995
Transmission
Toyota T100 M.T., 4 Cyl- K155 $250 Schronce Used Parts & Cars, Inc. USA-NC(Conover) Request_Quote 1-800-222-1046 Request_Insurance_Quote
1996
Transmission
Toyota T100 5SP,05-96 0 A 027086 $Call Brandywine Automotive Centers USA-MD(Brandywine) Request_Quote 1-866-214-2175 Request_Insurance_Quote
1995
Transmission
Toyota T100 5SP,4CY,1/2TON,MT 009617 $Call Feezle Auto Wrecking USA-PA(Enon-Valley) Request_Quote 1-724-336-5512 Request_Insurance_Quote
1994
Transmission
Toyota T100 1193,2.7,STDFLR 132,892 A L70564 $Call W J Lee Used Cars and Parts Inc. USA-SC(Effingham) E-mail 800-922-9771
1996
Transmission
Toyota T100 5SP,05-96 0 A 027086 $Call Bowie Truck - Yard #2 USA-MD(Bowie) Request_Quote 1-866-214-2175 Request_Insurance_Quote
1995
Transmission
Toyota T100 BELL HOUSING HAS BROKE PLACE CK 138,000 A 4B4193 $Call Nichols Auto Parts USA-KY(Elizabethtown) Request_Quote 1-800-999-2702 Request_Insurance_Quote
1995
Transmission
Toyota T100 10-94,RWD,2.7,F5,FLR,STD N00377 $Call Art's Parts USA-OH(Middletown) Request_Quote 1-800-404-7133 Request_Insurance_Quote
1995
Transmission
Toyota T100 60,000
--km--
96,618 A P10052 $Call Vance Hanes Auto Parts Can-NS(Upper-Brookside) E-mail 1-800-565-2433
1996
Transmission
Toyota T100 2-96,2.7,FMT5,4X2,TSTD 976375 $Call Rockville Used Auto Parts USA-MD(Rockville) E-mail 1-301-279-5833
1997
Transmission
Toyota T100 77588 $Call Global Auto Parts USA-MI(Detroit) E-mail 1-313-866-8888
1995
Transmission
Toyota T100 2.7,5SP MANUEL,RWD,FIX,Floor C06071 $Call Jonesboro Auto Salvage USA-GA(Jonesboro) E-mail 1-770-477-6663
1996
Transmission
Toyota T100 STOCK NO. 004746015 004746015 $Call Universal Auto Recycling USA-KY(Benton) Request_Quote 1-270-527-3431/1-800-443-8578
1996
Transmission
Toyota T100 STOCK NO. 005093022 005093022 $Call Universal Auto Recycling USA-KY(Benton) Request_Quote 1-270-527-3431/1-800-443-8578
1994
Transmission
Toyota T100 M/T, 4CYL TRANSMISSION 2WD PS1051 $Call K & P Auto Dismantlers USA-CA(Fontana) Request_Quote 877-Pick-kp1 / (877-742-5571) / 909-428-6898 Request_Insurance_Quote
1995
Transmission
Toyota T100 1J0997 $Call LeBarron's Auto Salvage, Inc. USA-PA(Dover) Request_Quote 1-717-292-3159 Request_Insurance_Quote
1995
Transmission
Toyota T100 5 Sp,4X2,Floor 4081 $Call Citron's Used Auto Parts & Light Truck Parts USA-TX(Odessa) E-mail 800-328-5974 / 432-381-2401
1994
Transmission
Toyota T100 0M9245 $Call ABC Auto Parts USA-AL(Birmingham) E-mail 205-841-8661 / 800-607-6151
1995
Transmission
Toyota T100 4 CYL, M.T. 2.7L, TESTED 007485 $Call Shorty's Auto Parts #1-ELITE USA-PA(King-of Prussia) Request_Quote 610-270-9810 / 888-333-9810 Request_Insurance_Quote
1996
Transmission
Toyota T100 DROVE C-20 $Call A and B Auto Parts USA-OH(Trotwood) E-mail 937-854-5323
1997
Transmission
Toyota T100 5SP 50125 $Call Rollins Auto Wrecking USA-WA(Spanaway) E-mail 800-675-9339 / 253-846-9393
1996
Transmission
Toyota T100 9077 $Call Gary Used Auto Parts USA-FL(Opa-Locka) E-mail 305-688-8554 / 786-222-2031
1995
Transmission
Toyota T100 4CYC 5SPEED 2 1383 $Call Glisson Salvage, Inc. USA-IN(Evansville) E-mail 812-464-9062
1996
Transmission
Toyota T100 157,000 A $Call Howbill Auto Parts, Inc. USA-NY(Wellsville) E-mail 585-593-4074 / 866-939-2886
1994
Transmission
Toyota T100 051212 $Call International Auto Wrecking USA-CA(Fresno) Request_Quote 559-485-3555 Request_Insurance_Quote
1994
Transmission
Toyota T100 MT 531873 $Call International Auto Wrecking USA-CA(Fresno) Request_Quote 559-485-3555 Request_Insurance_Quote
1995
Transmission
Toyota T100 NOF $Call J&V Auto SALVAGE-ELITE USA-NY(South-Hampton) Request_Quote 631-283-5111 Request_Insurance_Quote
post #15 of 23 Old 08-01-2014, 11:38 PM
BamZipPow's Avatar
Quoted: 892 Post(s)
Wink
Part number fer the 11:27 gear is 33403-39135. Discounted price online is about $29 plus shipping. Looks like MSRP is around $40. I guess that's better than a few hundred bucks plus install fer a different transmission.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100 Forum
User Tag List
Linear Mode Linear Mode
