2005-2009 frame recall letter - Toyota Nation Forum : Toyota Car and Truck Forums
Toyota Recalls
Find out about the history of your next vehicle and learn how to track the history of your current vehicle.
 1Likes
post #1 of 179 Old 05-27-2014, 11:06 AM Thread Starter
Car Dealers Suck !
TheKneebiter's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Received a letter from Toyota. Frame recall in the cold climate salt states. If frame has no rot they clean it and paint it with special sauce. If it is rusted through they say they will fix it.
TheKneebiter is offline
post #2 of 179 Old 05-27-2014, 11:07 AM
readmerry's Avatar
Quoted: 0 Post(s)
Do you have a pic of the letter?
Also what state are you in? I am in PA so I would imagine that would be one of the included states.
Sent from AutoGuide.com Free App
readmerry is offline
post #3 of 179 Old 05-27-2014, 11:21 AM Thread Starter
Car Dealers Suck !
Quoted: 0 Post(s)
(Thread Starter)
States included in letter.
CT. DE. IL. IN. KY. MA. MD. ME. MI. MN. NH. NJ. NY. OH. PA. RI. VA. VT. WI. WV.
Letter reads
Toyota has received reports that certain 2005 through 2009 model year Tacoma vehicles operated in specific cold climate areas with high road salt use may exhibit more-than-normal corrosion to the vehicles frame. Toyota investigated these reports and determined that the frames in some vehicles may not have corrosion-resistant protection sufficient for use in these areas.
This combined with prolonged exposure to road salts and other environmental factors, may contribute to the development of more-than-normal rust in the frame of some vehicles. This condition is unrelated to and seperate from normal surface rust which is commonly found on metallic surfaces after some years of usage and/or exposure to the environment.
post #4 of 179 Old 05-27-2014, 11:25 AM Thread Starter
Car Dealers Suck !
Quoted: 0 Post(s)
(Thread Starter)
Any authorized participating Toyota dealership located in the cold climate states will inspect the condition of your vehicles frame. Based on the results of Toyota's inspection, If significant rust perforation is not found. Toyota will apply CRC to key areas of your vehicles frame at no charge to you..
post #5 of 179 Old 05-27-2014, 11:29 AM Thread Starter
Car Dealers Suck !
Quoted: 0 Post(s)
(Thread Starter)
You must have your vehicle inspected before March 31, 2016. If the Toyota Dealership confirms that your vehicles frame has significant rust perforation the dealer will provide an appropriate remedy at no charge
post #6 of 179 Old 05-27-2014, 04:17 PM
08TRDOFFROAD's Avatar
Quoted: 84 Post(s)
It is about dang time! They should have to extend this to any area that uses road salt. Mine has started to rust so bad when it rains it leaves rust stains on the concrete in the garage where I park it. Haven't crawled under to check for perforations, but I know it is only a matter of time. My hope of being able to pass this truck on to my son when he is old enough to drive are fading fast...
08TRDOFFROAD is offline
post #7 of 179 Old 05-27-2014, 08:22 PM
Currently Drinking
Quoted: 0 Post(s)
No ND? Really?
jeremiahbwhite is offline
post #8 of 179 Old 05-27-2014, 08:52 PM
GOT SN❄W?
05Moose's Avatar
Quoted: 1868 Post(s)
I guess after replacing a few frames they seem to have awaken. One of the gals in our NorCal group knew someone that worked at NUMMI before they closed, and he said that they used to get frame shipments in without the coatings on them to reduce rust. Can't remember if it was just oil or what, but he knew they were going to rust.
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
2010 Highlander 4WD
2019 Subaru Crosstrek Limited
05Moose is offline
post #9 of 179 Old 05-28-2014, 09:52 AM
Quoted: 7 Post(s)
Same thing happens in my garage.
Slimtv is offline
post #10 of 179 Old 05-28-2014, 01:06 PM Thread Starter
Car Dealers Suck !
Quoted: 0 Post(s)
(Thread Starter)
Dropped my truck off early yesterday morning. Was told it could take 3 days if it just needed paint because they remove the bed. More if they find a hole. I knew there was no hole because I am under there all the time. My frame is always washed. I scrape any flakes and paint with a rust paint every year.
Well They called me a little while ago and said all set. I drove the loaner which stunk like rotten chicken back, Pulled in and there was my truck in the lot. It has been raining hard for 2 days so I could not climb under but went to the rear wheel well and looked under. I saw a shiny black thick coat on the frame. Figured it looks good and proceeded to go into the service department.
Gave them the keys to the stink mobile and he handed me my keys and the paper. I walked to my truck. Got down on the rainy wet ground and took a look. It was all over my nice blue TRD shock boot and they did not remove my bed because I could see the top of the frame where there was no undercoat. I then touched it to find it was dripping wet and now all over my finger. Wiped it off and got into the truck.
Found a nice tag hanging from my rear view mirror that said Toyota thanks me for my patience and I should park it outside for 3 days because of the petroleum smell. Also not to wash my truck for 3 days or more.
Now , Is it ok to drive it in the pouring rain ? I would think this is worse than washing. The paperwork said they drilled 2 holes in the closed part of the frame and sprayed paraffin wax in there. The rest of the frame was hit with undercoat.
I am not looking forward to see the mess under there when the weather allows me to look.
post #11 of 179 Old 05-28-2014, 05:05 PM Thread Starter
Car Dealers Suck !
Quoted: 0 Post(s)
(Thread Starter)
Just went out to the driveway and took a look. It is dripping and hanging off the frame. Lucky my driveway is not concrete or pavers as it is all over the place.
post #12 of 179 Old 05-29-2014, 01:48 PM
Gone skiing
Quoted: 2 Post(s)
I just got mine back from having the initial frame inspection. The report states "Misc inspected frame no rust perforation found at this time, will reschedule for undercoating. It also says "Performed EOD frame inspection. Frame is not rotted at this time." That gives me a warm fuzzy feeling. Hey Kneebiter, can you provide a list of do's and don't after coating since you have gone through the process?
gbeers is offline
post #13 of 179 Old 05-29-2014, 02:22 PM Thread Starter
Car Dealers Suck !
Quoted: 0 Post(s)
(Thread Starter)
Not sure what you mean by do's and dont's
But i will tell you this. Do not touch it when you get it back. This stuff is wet and not drying too quick. Do not park in your driveway if it is concrete or pavers because the black undercoat drips off onto the driveway. Do have a can of mineral spirits and a rag handy to clean off your mud flaps and shocks if you do not want undercoat on them.
I wiped the blue boots on my TRD shocks clean today. I also thought my flaps were wet but on closer look they were covered with undercoat as well as my factory side steps. Wiped them clean also. It has been more than 24 hours and this stuff is still dripping and wet. Maybe if it was 80 deg out it would dry quicker but we are in the 60s. And it rained all day yesterday.
If you want a show piece on the underside of your truck do not get it done. If you want it black shiny and textured with runs and blobs go for it.
The Following User Says Thank You to TheKneebiter For This Useful Post:
gbeers (05-30-2014)
post #14 of 179 Old 05-29-2014, 02:28 PM Thread Starter
Car Dealers Suck !
Quoted: 0 Post(s)
(Thread Starter)
They give you a loner as well. I called my dealer where I purchased the truck and was told I needed to leave it for inspection for a day with no loaner and if it needs painting they send it out. I replied " I DONT THINK SO" I then called the dealer just down the st from me and told them I received the letter and wanted to leave it with them and wanted a loaner. He said no problem bring it and leave it in the morning and we will have a car for you. I left it. they had it over night and called me the next morning and said it was done. I got the same report as you on the frame. But I did wash scrape spots and rust X my frame every year since new.
post #15 of 179 Old 05-30-2014, 12:18 PM
Powder Seeker
Quoted: 1 Post(s)
Can someone post a copy of this letter I can print and take into my local dealer. I find it odd we haven't received this same letter here in Canada yet.
Bike - Hike - Ski
2008 TRD Sport Double Cab 4x4 - Pearl Black
Dcaplan is offline
The Following User Says Thank You to Dcaplan For This Useful Post:
08TRDOFFROAD (05-30-2014)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Toyota Recalls
User Tag List
Linear Mode Linear Mode
