AVS Stepshield Door Sill Protectors - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 62 Old 03-30-2006, 07:38 AM Thread Starter
Synchman's Avatar
Quoted: 0 Post(s)
(Thread Starter)
AVS Stepshield Door Sill Protectors - Put these on yesterday, I really like them. They are hard plastic, and wrap around the edge of the sill, against which I normally knock the mud off of my boots.
http://www.performanceproducts4truck...ill+Protectors
I first ordered the Toyota step shields, which don't cover much of the sill. I returned them and bought these.
They come in three colors, I got black so they won't show the dirt and shoe marks.
It was about 50 degrees in my garage, and the temperature of the sill needs to be above 65 degrees for the pressure sensitive adhesive to activate. So I set a coleman lantern under the sill. You know, the kind you put white gas or unleaded gas into, and then pump it up and light the mantle? This heated up the area nicely in about 30 minutes.
I dry-fit and marked the location with masking tape. On the fronts, I abraded ligtly with 2000 grit wet/dry sandpaper. The stepshields come with an alcohol wipe for each stepshield, but I abraded as I wanted to really make sure they stick. Then I wiped down really well with alcohol.
Near the top of Fig 1, you can see the backside of the stepshield. There is an adhesive strip with white release liner near the long edges. You peel this back about 2" at the ends to expose the pressure sensitive adhesive. After installing the stepshield, you grab the ends of the release liner and pull it out from underneath, exposing the remaining adhesive. This enables you to position the stepshield without it sticking all over the place. I had trouble keeping the exposed release liner ends out from under, so I finally taped them down to the top of the stepshield during the install.
Fig. 1: Front Drivers with install location prepped. Backside of stepshield shown near top of picture.
Fig 2. Close view of stepshield installed.
Fig 3. Top view of shepshield installed. You can see there is a pattern match between the stock plastic piece inboard of the stepshield, and the stepshield. The stepshield for the pax side shown sitting on the mud mat.
Fig 4. Top view of stepshield installed, Double Cab Rear.
Fig 5. Side view of stepshield installed, Double Cab Rear.
Keywords: Stepshield, Step Shield, Scuff Guard, Door Sill Protector, Door Sill Protection
Scott (Synchman)
2005 Taco DblCab LB V6 4X4 AT
2007 Rav4 V6 AWD AT Ltd
http://www.cardomain.com/ride/2287946/1
Last edited by Synchman; 06-12-2008 at 10:02 AM. Reason: Update pictures since Cardomain moved from .net to .com
Synchman is offline
post #2 of 62 Old 03-30-2006, 07:50 AM
Quoted: 0 Post(s)
defently alot more functonal than the factory tacoma ones.... good find
TAZZX2 is offline
post #3 of 62 Old 03-30-2006, 07:55 AM
Back40's Avatar
Quoted: 4 Post(s)
Nice...OK..any suggestions on removing the one's installed by the dealer? They have already chipped in several places because the dealer installed them with the edge hanging over the sill.
2005 Tacoma 4x4 Double Cab SR5
Back40 is offline
post #4 of 62 Old 03-30-2006, 08:03 AM Thread Starter
Synchman's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I can't take credit for finding these, there was a post on a forum that led me to them. I can't find the post anymore.
The factory ones are stuck on with pressure sensitive adhesive, so you would probably remove them with a hair dryer and fish line. Search for debadging, I expect you would use the same technique.
Scott (Synchman)
Synchman is offline
post #5 of 62 Old 03-30-2006, 05:00 PM
brulow's Avatar
Quoted: 0 Post(s)
Put mine on over the top of the old ones(factory),looks/works fine
brulow is offline
post #6 of 62 Old 03-30-2006, 06:52 PM
Pb
Surfing TN via iPhone
Pb's Avatar
Quoted: 0 Post(s)
iTrader Score: 15 reviews
Pop off the door sill panel and then heat up the sill protector with a heat gun and it should peel off with a good pull.
Pb is offline
post #7 of 62 Old 03-30-2006, 06:56 PM
Pb
Pb's Avatar
Quoted: 0 Post(s)
Does it rub on the paint when the door is closed? What's this?
Pb is offline
post #8 of 62 Old 03-30-2006, 06:58 PM
Fitz235's Avatar
Quoted: 21 Post(s)
Those look way better than the factory ones, and I like that they don't say Tacoma on them.
Black 05 V6 AC 4WD TRD Offroad
Bilstien 5100's, 265/70/17 Toyo Open Country's, Lorado Tonneau, Factory DeeZee's
Fitz235 is offline
post #9 of 62 Old 03-30-2006, 07:09 PM
Quoted: 0 Post(s)
Looks like tape residue.
05'Pre-Rner, DC, Impulse Red, TRD OR #2, TRD Exhaust, TRD CAI, Fog mod
netranger6 is offline
post #10 of 62 Old 03-30-2006, 07:19 PM
Only 48 more payments.
Quoted: 0 Post(s)
Wow, i like the looks of that. Think that might be my next mod!
goldmember is offline
post #11 of 62 Old 04-02-2006, 10:10 AM
817
movielife's Avatar
Quoted: 0 Post(s)
What is this? Does it rub on the paint when the door is closed? Or is it tape residue?
movielife is offline
post #12 of 62 Old 04-02-2006, 01:27 PM Thread Starter
Synchman's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Must have been tape residue. I just went out and wiped it away.
Scott (Synchman)
Synchman is offline
post #13 of 62 Old 04-02-2006, 01:49 PM
My name is Blake
Quoted: 0 Post(s)
Damn.
Those are pretty sweet my friend.
For $29 that is not bad at all.
NorCalTacoma is offline
post #14 of 62 Old 04-03-2006, 05:58 AM
Quoted: 0 Post(s)
I ORDERED A SET OF GRAY ONES BACK IN fEB FROM PROFORMANCE PRODUCTS AND THEY HAVE BEEN BACK ORDERED SINCE THEN!!!!!
ANYONE KNOW WHERE ELSE I MAY BE ABLE TO GET A SET?!?!?
(Sorry bout the caps)
2006 Tacoma Double cab, V6,6 speed manual,4X4 TRD Sport.
The only mod so far is tinted front windows.
usmcski is offline
post #15 of 62 Old 04-03-2006, 07:35 AM Thread Starter
Synchman's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I don't hear it rubbing when I close the door. How else could I check?
Scott (Synchman)
Synchman is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
