scan gauge failure? - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 5 Old 04-06-2019, 01:22 PM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
scan gauge failure?
I have had my scan gauge since late 2005, it generally displays FWT, VLT, MPG, & FIA. Each time I fill up I also input the gallons so I generally get the estimated MPG ranges accurately.
Every two weeks, I make the same 400 mile trip picking up and dropping off kids... my MPG's average has been 19-20... Freeway speed, 70 MPH...
Past month or so, fill ups have said I should put in twice the gallons of what I actually do. The MPG displayed is less then half what I actually get. (I have checked it with the gas receipt, miles driven against the gallons used. 20 MPG)
So either the scan gauge is end of life or the sensor in the Tacoma the gauge references to calculate such, has failed?
Anyone replaced a scan gauge because of end of life?
anyone have a clue which sensor, and location? So I can unplug and reseat? I say this because 5,000 miles or so ago I had new head gaskets installed. And its easily possible a sensor plug isn't properly seated or loose?
'05 prerunner access trd sprt pkg1 w/tow & trd catback
yrffej is offline
post #2 of 5 Old 04-06-2019, 02:25 PM
Senior TN Member
cb91710's Avatar
Quoted: 1651 Post(s)
Any chance one of the kids messed with it?
There is a manual calibration for fuel consumption on the Ultragauge, I would imagine the Scangauge has the same.
-- Rich
cb91710 is offline
post #3 of 5 Old 04-06-2019, 04:51 PM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
na...
the manual calibration happens each time you fill it up. it does display a suggested amount, but you do also input the gallons you actually put into it.
that's just the calibration for gallons used and remaining, hours driven and remaining, MPG.s per tank. (which have been incorrect, since)
along with that, while using the gauge displaying MPG... when I'm going downhill at freeway speed, and let off the gas. In the past the gauge would display sometimes 60-99 MPG (because the hill at speed had my gas consumption at 0...) Now the best I get, is like 20+ MPG...
Not sure if its the gauge or sensor feeding the scan gauge, at fault?
yrffej is offline
post #4 of 5 Old 04-08-2019, 02:30 PM
Senior TN Member
RTFM's Avatar
Quoted: 115 Post(s)
If you own another car, or know someone who owns another car, I would move it over there (unless you followed PB and built it in), and see if it reads reasonably or 1/2 over there.
I would guess sensor before Scan Gauge, that's too weird a failure. I would expect it to just stop talking to the car or displaying if it failed, not just one reading going it. Its not reading each sensor individually, its peeling things off a bus signal I assume.
06 DC LB 4x4 Speedway, TRD Sport w/ Tow, JBL w/ Grom to IPod / Aux / BT, Roof Rack, Weathertech bug deflector & floormats, Access LE tonneau, Clifford 10.5x alarm, Homelink Mirror, Ultra Grinder Wheels, Michelin LTX MS2 tires
RTFM is offline
post #5 of 5 Old 04-20-2019, 09:45 AM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
it may have fixed itself? To soon to tell, cause I drive it now only every other weekend...
But I reset it to factory defaults, and it seemed to be displaying better that day on normal gauge.
I'll need to fill it up a couppla' more times, and input the fill-up amounts...
I will see... if MPG's on the tank get normal?
yrffej is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
