2008 wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
 1Likes
  • 1 Post By BamZipPow
post #1 of 7 Old 04-20-2019, 01:11 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
2008 wont start
All of sudden 2008 won't start.. replaced battery and I do hear fuel pump running.. anyone have an idea what's wrong.. It does try to start..
Bluefish0420 is offline
post #2 of 7 Old 04-21-2019, 11:48 AM
2004 Camry LE
somick's Avatar
Quoted: 66 Post(s)
Do you hear any clicking?
Does your engine rotate?
Observe the speedometer needle. Does it bounce?
Good luck,
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline
post #3 of 7 Old 04-21-2019, 01:02 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Good luck,
Sam
yes the engine does rotate, not sure about speedometer..
post #4 of 7 Old 04-21-2019, 04:28 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 902 Post(s)
Wink
Welcome to the forums!
Have you carefully inspected yer fuses? Was any maintenance performed prior to this issue? Any aftermarket mods installed? How many miles on the vehicle? Has this vehicle been in an accident before? Have you checked to make sure you have fuel in the fuel tank?
somick likes this.
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, dual oil catch jars, AC mod, aero cap, lower aero package, 67% grill block, aero single wheel trailer
BamZipPow is offline
post #5 of 7 Old 04-27-2019, 02:32 PM
BamZipPow's Avatar
Quoted: 902 Post(s)
Wink
One of the best and basic tools you can use to perform electrical diagnostics is a test light. It can confirm power and ground to a device or wiring harness. It won't take a lot of training but logic in the approach on determining where yer not gitting power at. You can find this test light at various stores including yer car parts stores, Harbor Freight, or even a garage sale. Good luck!
post #6 of 7 Old 04-28-2019, 06:27 PM
My Other Truck
Splicer's Avatar
Quoted: 458 Post(s)
Check the easy stuff first. Is there gas in the tank? Crack a line to see if fuel is getting to the engine. Are the spark plugs sparking? Has any work been done under the hood recently?
2005 D-Cab O/R 4x4
Splicer is offline
post #7 of 7 Old 04-28-2019, 06:57 PM
Moderator
ukrkoz's Avatar
Quoted: 867 Post(s)
In order to start, engine needs as follows:
- fuel
- spark
- air
-timing.
With any one of those at fault, engine will not start. Hence, you need to check that you have fuel, spark is good, air filter is good and timing is as it should.
Out of all, as you mentioned that it is "sudden", my first guess will be torn belt, if you have belt. Torn, or skipped. Chains skip too, btw. The other culprits would have built up problems over time. You said pump is whirring - but do you have fuel to injectors?
ukrkoz is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
