Towing with highlander hybrid - Page 14 - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander Hybrid The first hybrid SUV from Toyota, the Highlander Hybrid!
 8Likes
post #196 of 204 Old 01-16-2019, 09:58 AM
Moderator
ukrkoz's Avatar
Quoted: 867 Post(s)
We had same issue with RX300 and it was bad heating element. I'd suggest to check for continuity in it. I am not really an electrician, but have no doubt it can be done. Also, check heating element plug for 12V. If you have 12V, it's element. Mof, the switch itself can go bad, right?
Start with determining if you have power to the element. Then work your way down from that.
ukrkoz is online now
post #197 of 204 Old 01-16-2019, 10:54 AM
EJO
Quoted: 44 Post(s)
ukrkoz
Thank you for your reply.
I tried Highlander 1st gen with 1 unrelated reply hence I went here. It has noting to do with Hybrid it is a interior Highlander or like yours RX300 or RX350 factory type option and therefore tried to get an answer here.
I have continuity I have good clean contacts just not always heat. Being a process of heating a coil with higher amperage I assume it is switched on and off via a relay.
My owners manual is not like in cars the olden days when it basically was a shop manual.
The question therefore is where are these relays located and are they replaceable.
EJO is offline
post #198 of 204 Old 01-16-2019, 11:16 AM
Toyota Collector
71Corolla's Avatar
Quoted: 2459 Post(s)
I've worked on several Toyota and Lexus models with heated seats there was no relay the switch supplied power to the element directly. To diagnose this hook up a light bulb by back probing the connector and watch to see if it stays on solid. The cars I worked on had bad heating elements replacing them is no fun.
ukrkoz likes this.
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is online now
post #199 of 204 Old 01-16-2019, 11:40 AM
EJO
Quoted: 44 Post(s)
OK thank you
Time to sell the car as that will be a lot less hassle to keep the wife happy. In the meantime while it is cold we'll drive the Subaru as those heated seats work perfect.
EJO is offline
post #200 of 204 Old 01-21-2019, 12:57 PM
Moderator
ukrkoz's Avatar
Quoted: 867 Post(s)
To address #16 post:
Conventional Highlander engine
  • 295 horsepower
  • 263 lbs.-ft. of torque
  • Compression Ratio10.8:1
  • 23 mpg combined
  • 5,000-pound max trailer weight
Hybrid Highlander engine
  • 231 horsepower
  • 215 lbs.-ft. of torque
  • Compression Ratio
    12.5:1
  • 29 mpg combined
  • 3,500-pound max trailer weight
Atkinson cycle is electronically simulated via VVT-I system, controlled by ECM.
Original Atkinson engine has additional components, not implemented in conventional engines
"Cycle Engine" This engine used poppet valves, a cam, and an over-center arm to produce four piston strokes for every revolution of the crankshaft. The intake and compression strokes were significantly shorter than the expansion and exhaust strokes.
.2AZ-FXE
The 2AZ-FXE is an Atkinson cycle variant of the 2AZ-FE. It has the same bore and stroke, but the cams and pistons are unique. It has a physical compression ratio of 12.5:1.
The large valve overlap leads to a reduction in cylinder charge and reduced torque and power output, but efficiency is increased. This combination makes the 2AZ-FXE suitable for use only in hybrid vehicles, where peak torque and power demands can be met by the electric motor and battery.
Maximum output when used in the Camry hybrid is 211 hp (147 kW) at 6000 rpm with 108 lbft (257 Nm) of torque at 4400 rpm.
etp7 likes this.
post #201 of 204 Old 01-22-2019, 07:57 AM
TheTexasKellys's Avatar
Quoted: 20 Post(s)
Well with conflicting info here and from our dealer we’ve gone with the “no problem” opinions. We have the towing package on our 2017 Limited Platinum HiHy and took our 1500 lb popup camper about 300 miles from Houston to San Antonio and back. It towed like a champ, like the camper wasn’t even there. Much better than our old Honda Odyssey3.5L V6. We’re sold, and looking forward to lots more camping trips! We did drop from a 27 average MPG to to under 15 but that’s to be expected. And we DID follow the manual’s advice and DID NOT use cruise control, even though it was mostly level traveling with few hills or upgrades.
etp7 likes this.
TheTexasKellys is offline
post #202 of 204 Old 02-05-2019, 02:42 AM
B52D,F,G,H
etp7's Avatar
Quoted: 8 Post(s)
Smile
My advice if you are shopping for a new vehicle and you need to tow alot is buy a vehicle designed from the ground up to do heavy duty towing.
My salesman said no when I asked him about a towing package.
Since I do not normally tow this was not a deal breaker for me. Strongly suggest a HD truck or 4 Runner for towing.
So the question is does the Platinum have any prewiring etc for a hitch?
Great thread BTW and right on topic.
2019 Platinum Hybrid
etp7 is offline
post #203 of 204 Old 06-04-2019, 01:08 PM
Quoted: 1 Post(s)
towing gen 2 HH ANY coolers to add?
I have gone through the links about towing with the Highlander and still haven't' found one answer.
Q: Do ANY additional coolers (engine/transmission?/inverter) NEED to be added to the Highlander Hybrid to tow 3,500 lbs?
Or.....IS the HH ready to tow up to 3,500lb once the wiring systems and hitch are installed?
I will be installing an electric brake controller and already have a factory hitch. A lot of manufacturers add fluid coolers and springs for towing purposes. Then call it a "towing package". I just haven't read anything specific on the Highlander Hybrids.
BTW, so far towing a 1,700 trailer has been easy.
thanks in advance!
Jeff
jeff3113 is offline
post #204 of 204 Old 06-14-2019, 06:05 PM
Quoted: 1 Post(s)
FYI. Two separate calls to Toyota dealer service departments gave the same answer. Electric brake wiring install with proper hitch and the HYBRID is set for 3,500lb towing. No coolers needed.
jeff3113 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Highlander Hybrid
Tags
2016 , boat , canada , cvt , harness , highlaner , hybrid , hybrid towing , regenerative braking , tow rating , towing , wire
User Tag List
Linear Mode Linear Mode
