2004 Tundra Soft Breaks...HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Tundra 1st Generation (20002006) Looking for dedicated discussion for the 1st Generation of the Toyota Tundra? This forum is the place for you.
post #1 of 3 Old 09-26-2015, 08:09 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ok, so I've a 2004 Tundra Extra-Cab 4x4. My breaks have been very spongy for a few months and getting worse. I bought a vacuum pump/bleed kit and went around and bled the 5 bleed ports I could find. One on each hub and the one above the diff. Still spongy so I took it to the shop and they bled it with a "power bleeder" still spongy, they found my front calipers were bad , not all the pistons were moving, and replaced them... still spongy. So they said it was the Master Cylinder and replaced it. Still Spongy. He told me he bled it 5 times, still spongy. He says he has no idea what to check next... and neither do I.
Oh, and I live in bush Alaska, truck was barged in 7 years ago from Seattle. No roads connecting to anywhere else in the state so there's no Toyota dealership options.
Any ideas what else it could be or what I should check next?
Cakayaq is offline
post #2 of 3 Old 09-28-2015, 07:32 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Also, just a little more info... while I wait to get this fixed, I don't have a car. Any help would be appreciated....
Cakayaq is offline
post #3 of 3 Old 09-29-2015, 08:20 PM
topdeadcenter's Avatar
Quoted: 42 Post(s)
Check the metal brake lines for corrosion and also the rubber lines; cracks in vacuum line off brake booster?
Does it have ABS?
topdeadcenter is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > Tundra 1st Generation (20002006)
User Tag List
Linear Mode Linear Mode
