2006 V8 4.7 Timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Tundra 1st Generation (20002006) Looking for dedicated discussion for the 1st Generation of the Toyota Tundra? This forum is the place for you.
post #1 of 6 Old 12-30-2015, 11:34 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
My truck has 112,xxx now and i have not yet replaced the timing belt. Toyota recommends replacing at 100,000 but I was told by a mechanic that I trust that it is OK to wait longer. Any thoughts on how long is safe before I should change it?
tdave15 is offline
post #2 of 6 Old 01-01-2016, 02:49 AM
Quoted: 0 Post(s)
About 22,000 miles ago? It should have been changed at 90k. Although I've heard some people have gone 200k without changing it, I wouldn't risk it and would plan on having it done a.s.a.p.
JohnnySixString is offline
post #3 of 6 Old 01-02-2016, 09:54 PM
Quoted: 0 Post(s)
I just changed mine on my 06 tundra double cab 4.7 L 4x4 with 104,000 miles belt was totally shot ,cracks every 1/8 inch it could have gone any time CHANGE IT my water pump was leaking a bit also so I changed it.
Code4fire is offline
post #4 of 6 Old 05-02-2016, 08:37 AM
ClutchColton
Quoted: 1 Post(s)
I'm in the process of changing my timing belt on my 06 Tundra with 102k miles. Haynes manual recommended every 80-90k miles. My belt shows no signs of wear. Only changing it for preventative maintenance. I had a 97 avalon that went over 160k miles on one belt and it still looked good as well.
I'm not wanting to take chances on this good truck so I'm changing it.
Clutchcolton is offline
post #5 of 6 Old 08-27-2016, 02:10 PM
wonger's Avatar
Quoted: 8 Post(s)
I belt is probably still good but I bet your truck the water pump has started leaking. I would replace it. Why risk the cost of an engine for an easy repair.
Sent from my iPad using Tapatalk
88 4Runner
wonger is offline
post #6 of 6 Old 10-09-2016, 03:47 AM
Notsojingo's Avatar
Quoted: 2 Post(s)
Always better to not push limits, and as well change water pump same time.
Why risk it if you can afford not to.
Notsojingo is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > Tundra 1st Generation (20002006)
User Tag List
Linear Mode Linear Mode
