2005 tundra o2 - Toyota Nation Forum : Toyota Car and Truck Forums
Tundra 1st Generation (20002006) Looking for dedicated discussion for the 1st Generation of the Toyota Tundra? This forum is the place for you.
post #1 of 2 Old 02-17-2017, 08:26 PM Thread Starter
Moderator
75aces's Avatar
Quoted: 1019 Post(s)
(Thread Starter)
2005 tundra o2
I have a CEL and according to torque my timing is advanced 24 degrees. Cleared the code and it is back again. Will try to clean the maf and throttle body. Is pcv suspect too? What about the o2?
Fuel Status = 0 byte
Engine Load = 7.451 %
Engine Coolant Temperature = 181.4 F
Fuel Trim Bank 1 Short Term = 0 %
Fuel Trim Bank 1 Long Term = -0.781 %
Fuel Trim Bank 2 Short Term = 0 %
Fuel Trim Bank 2 Long Term = 1.562 %
Engine RPM = 1,500 rpm
Speed (OBD) = 46.603 mph
Timing Advance = 24
Intake Air Temperature = 48.2 F
Mass Air Flow Rate = 5.37 g/s
Throttle Position(Manifold) = 15.686 %
Air Status = 0 byte
Run time since engine start = 612 s
O2 Sensor1 Equivalence Ratio = 1.235
O2 Sensor5 Equivalence Ratio = 1.235
Distance travelled since codes cleared = 16.777 miles
Barometric pressure (from vehicle) = 14.504 psi
Catalyst Temperature (Bank 1,Sensor 1) = 1,195.16 F
Catalyst Temperature (Bank 2,Sensor 1) = 1,195.16 F
Catalyst Temperature (Bank 1,Sensor 2) = 1,167.08 F
Catalyst Temperature (Bank 2,Sensor 2) = 1,167.08 F
Voltage (Control Module) = 13.925 V
Engine Load(Absolute) = 7.451 %
Commanded Equivalence Ratio(lambda) = 1.005
Relative Throttle Position = 0 %
Absolute Throttle Position B = 47.843 %
Accelerator PedalPosition D = 16.078 %
Accelerator PedalPosition E = 32.157 %
75aces is offline
post #2 of 2 Old 04-01-2017, 12:20 PM
Quoted: 0 Post(s)
What code number came up when checked?
ccornell is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > Tundra 1st Generation (20002006)
User Tag List
Linear Mode Linear Mode
