2000 Toyota Tundra V8 Clicking Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Tundra 1st Generation (20002006) Looking for dedicated discussion for the 1st Generation of the Toyota Tundra? This forum is the place for you.
post #1 of 5 Old 08-22-2018, 08:26 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Hello Toyota Nation,
I own a 2000 Toyota Tundra V8 and am having a clicking noise problem when I am accelerating. It clicks more rapidly when I step on the gas pedal.
Any suggestions or other threads that have solved this problem with their 2000 Toyota Tundra?
Thank you.
daochoua is offline
post #2 of 5 Old 08-23-2018, 10:50 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 900 Post(s)
Wink
Welcome to the forums!
I need more info, please.
2WD or 4WD? Auto or manual transmission? How many miles on the vehicle? Any aftermarket modifications or installs like a lift or suspension? Is the click from the engine or drivetrain? Could you safely shoot some video and post it? Thanks!
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, dual oil catch jars, AC mod, aero cap, lower aero package, 67% grill block, aero single wheel trailer
BamZipPow is offline
post #3 of 5 Old 08-27-2018, 06:40 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
It's a 2WD automatic transmission with 313k miles. The clicking noise comes from the driver side when I push the accelerating pedal and becomes more louder/faster as I accelerate faster. I don't know if it's the engine or the drivetrain.
daochoua is offline
post #4 of 5 Old 08-30-2018, 12:56 AM
BamZipPow's Avatar
Quoted: 900 Post(s)
Wink
You can easily isolate either or by shifting the transmission to neutral when it's safe to do so while yer at speed. If the clicking dies down when the engine idles, then you'll have a good idea that it's an engine click. If it doesn't, then it's gonna be most likely a transmission/drivetrain issue. Are you sure it's not a bearing or wheel assembly?
post #5 of 5 Old 12-19-2018, 02:55 AM
damcelhannon's Avatar
Quoted: 3 Post(s)
I'd ask if the noise is there after an oil change? What kind of oil and filter are you using? Does the temperature of the engine make a difference? Can you hear the noise at idle at all and if you can is it louder from under the hood or down by the oil pan?
The more details you can give the forum, the better the help you'll get...
damcelhannon is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > Tundra 1st Generation (20002006)
Tags
2000 toyota tundra , clicking noise
User Tag List
Linear Mode Linear Mode
