‘04 V8 2WD double cab...need help please - Toyota Nation Forum : Toyota Car and Truck Forums
Tundra 1st Generation (20002006) Looking for dedicated discussion for the 1st Generation of the Toyota Tundra? This forum is the place for you.
post #1 of 2 Old 12-29-2018, 08:05 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
04 Tundra V8 2WD
New on here and looking for help from anyone that may have experience with my problem. My son’s truck has 230k and was loosing power and running rough. Replaced coils, plugs in hopes of correcting the problem. It’s running smoother but still doesn’t have any power. Checked the timing, which is perfect and cleaned intake. We have also recently changed oil, oil filter, oil pressure sensor due to low pressure reading on gauge as well as changing the fuel pump. Now it has a knocking that has started along with the loss of power. This truck should be running better by now. Help please....
Maurielle2 is offline
post #2 of 2 Old 12-31-2018, 11:49 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 883 Post(s)
Wink
Welcome to the forums!
How many miles on the truck? Any maintenance performed prior to this issue? Any aftermarket mods installed? Is the check engine light on? If so, what were the exact codes pulled? What was the fuel pressure reading before and after you replaced the fuel pump? Has the fuel filter been replaced?
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, dual oil catch jars, AC mod, aero cap, lower aero package, 67% grill block, aero single wheel trailer
BamZipPow is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > Tundra 1st Generation (20002006)
User Tag List
Linear Mode Linear Mode
