04 - 06 tundra, 04 - 07 sequoia - ball joint issues - Toyota Nation Forum : Toyota Car and Truck Forums
Tundra 1st Generation (2000–2006) Looking for dedicated discussion for the 1st Generation of the Toyota Tundra? This forum is the place for you.
post #1 of 3 Old 08-20-2010, 06:33 PM Thread Starter
02p1's Avatar
Quoted: 0 Post(s)
(Thread Starter)
04- 07 sequoia and tundras - ball joint issues
we had a bit of an experience with our 05 sequoia recently.
while backing out of the driveway, the castle nut that retains the lower left ball joint came off the stud, shearing through the cotter pin as it went, allowing the lower control arm to drop out and the left front suspension to collapse.
fortunately this happened in the driveway.
we had to have the car towed and both ball joints replaced. the bill was $700 – it would have been much worse had this happened on the road and things been torn up when the suspension collapsed.
turns out that there was a safety recall back in 2007. the ball joints on midyear ’04 through mid year ’07 tundras and sequoias were bad, and toyota had to replace them.
there is a toyota technical correspondence memo that describes the problem and the recall. it also list the ranges for the VINs involved. it was dated january 18, 2007 and is numbered TC07-002.
our sequoia was a part of the recall class and the lower ball joints were replaced by a las vegas area dealership in summer of ’07. (the car was originally sold in vegas - we bought it used in march of 2009.)
apparently, though, the work was not done correctly. when we got the old parts back after the repair, the stud on the left front ball joint was rusted. this points to a condition in which the retaining castle nut was never really snugged up into place when the joint was replaced in ’07. it has apparently been loose this entire time. perhaps it was even cross-threaded. many of the threads on the stud were stripped. further, the mechanic who made the repair told us that the castle nut on the right lower ball joint was only finger tight. while tighter than the left side that failed, and not exhibiting the rust that the left side showed, it appears that it too had never been properly torque into position.
in addition to apparently sloppy work at the dealership where the repair was done, this condition was also missed by the dealership that sold us the vehicle – both in their presale “multi point safety inspection” and during subsequent routine services that also supposedly included “multi point safety inspections.”
so, if your tundra or sequoia is ’04 through ’07, questions you may want to ask:
· was it part of the recall class? (see the tech memo for VIN ranges)
· if so, was the work done, were the ball joints replaced as part of the recall? any toyota dealer should be able to look up the VIN in the service database and find out.
· if so, was the work done properly? perhaps next time you have the vehicle serviced, you should have the mechanic check the joints to see that they are properly tightened up.
feel free to pass this along to anybody you know who has an ’04 – ’07 tundra or sequoia.
02p1 is offline
post #2 of 3 Old 09-25-2010, 10:45 AM
Trd racer
tundrav8yamaha's Avatar
Quoted: 144 Post(s)
had mine done in 2007 but i'll have it checked again with my service advisor.
tundrav8yamaha is offline
post #3 of 3 Old 07-04-2012, 03:50 PM
Quoted: 0 Post(s)
This just goes to show that a dealership, regardless of the owner's intentions, is only as good as its weakest employee. Obviously, the issue is compounded even further by Toyota (and other manufacturers, including Honda) who continue to replace recalled defective parts with the same part that has been recalled! I guess they figure that they have fulfilled their obligation of replacing the "recalled part." My 2005 Tundra Crew Cab was supposed fitted with the "improved ball joints" as part of the recall. It has approximately 55,000 miles. When I do a hard left or right turn (steering wheel all t he way either left or right), the truck sounds like a 30 year old truck, with a grinding metal to metal sound. I am going to replace both lower ball joints myself with quality Moog units. Of course, there is the front rotor warpage issue. I replaced the factory rotors with drilled units that use Canadian steel. Have not had any issues since then. I had a 1995 Camry that also had rear brake issues (it sounded much like an old car with metal to metal brake shoes grinding against the drums). Toyota just can't seem to get the right brake system design for dependable, quiet performance. Seems like they need to come back to Detroit and visit GM facilities (like they did back in the '60's) to take back to Tokyo good brake system design ideas. Don't get me wrong, overall I think Toyota makes a great car (Honda does to) and I will continue to buy and drive them. But, they (Japanese car makers) seem to be heading toward the same downfall that took down the US auto industry prior to the latest turnaround... We'll keep watching...
SoCalTundra05 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > Tundra 1st Generation (2000–2006)
User Tag List
Linear Mode Linear Mode
