94 4Runner 3.0 fuel pressure drops to zero - Toyota Nation Forum : Toyota Car and Truck Forums
4Runner Lounge General discussion area for all generations of the Toyota 4Runner.
post #1 of 4 Old 01-05-2019, 12:23 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Anyone idea: no fuel leaks, engine runs OK, fuel pump new, fuel pressure regulator new, injectors new. Engine shut down fuel pressure immediately drops to zero. Vehicle specific manual say's fuel pressure should remain above 21 psi for 5 minutes. Hard to start at times. Could be related?
turner_resort is offline
post #2 of 4 Old 01-05-2019, 01:16 PM
Senior TN Member
sdspeed's Avatar
Quoted: 354 Post(s)
It shouldn't drop to zero.By maintaining pressure the system is always primed so your starting issue is most likely related. Is the CEL on? Did you do a check for codes? Possible bad gas cap and/or a bad check valve in the nw fuel pump. If the check valve is faulty the fuel just returns to the tank.
After replacing all the parts you mentioned did it ever run correctly> OEM or after-market parts?
sdspeed is offline
post #3 of 4 Old 01-07-2019, 01:54 AM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 900 Post(s)
Wink
There are a few tests that you can isolate where yer fuel pressure loss is occuring at. Where did you hook up yer fuel pressure gauge at? Are you sure it's a good connection with no leaks?
Did you replace the parts with OEM or aftermarket parts? If aftermarket, which brand(s) did you use?
Are the injectors new or refurbished? There are instances where refurbished injectors were still leaking while under pressure. Did you replace the cold start injector as well?
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, dual oil catch jars, AC mod, aero cap, lower aero package, 67% grill block, aero single wheel trailer
BamZipPow is online now
post #4 of 4 Old 01-07-2019, 02:09 AM
BamZipPow's Avatar
Quoted: 900 Post(s)
Wink
I know this thread is about the 3.0 engine but this referenced thread is about the injector issue.
https://www.tacomaworld.com/threads/...4l-5vz.354399/
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4Runner Lounge
User Tag List
Linear Mode Linear Mode
