96 Tacoma manual transmission (4cyl) - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 1st Generation (1995.52004) 1st generation Tacoma information and discussion.
post #1 of 3 Old 05-04-2019, 09:45 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I recently bought a 96 Tacoma, and the stick started slipping out of gear (in 3rd and 5th) while driving. I read that it might be low/ bad fluid, so I'm in the process of filling the fluid up. Do I need to drain&flush the fluid (since I don't know what kind/brand is in there), or should I just try filling it with what I can get from the auto parts store?
Also, it seems as though the fluid was super low. Is there any maintenance I can do to mitigate any damage that might have happened while the fluid was low?
Any other tips or thoughts? Thanks!
Addertongue is offline
post #2 of 3 Old 05-05-2019, 10:19 AM
Quoted: 3 Post(s)
Its an easy fix! There is a plastic ring that goes around the shifter and it gets beat up, and its below the boot. You pull the shifter boot, and there it is.
brianzero is offline
post #3 of 3 Old 05-05-2019, 10:22 AM
Quoted: 3 Post(s)
And here it is, for $9:
https://www.rockauto.com/en/moreinfo...278918&jsn=386
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 1st Generation (1995.52004)
User Tag List
Linear Mode Linear Mode
