TechStream on Windows 8.1 64 Bit - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
General Discussion General discussion of basically anything automotive-related.
post #16 of 27 Old 08-30-2015, 09:17 AM
pdleung's Avatar
Quoted: 2 Post(s)
Originally Posted by ranger0 View Post
EFS463
Thanks - seems everything written says it won't work in 64 bit. I'm going to first try the XP Mode on my Win 7 64 laptop.
Thanks again
Bill
I just installed TechStream10.10.018 on my Windows 10 64-bit tablet. Here's the steps I followed:
1. Installed TechStream software
2. Extracted XHorse install package into temporary directory, e.g. in command shell
msiexec /a "MVCI Driver for TOYOTA.msi" /qb TARGETDIR=<destination path>
Where destination path = path to temporary directory
3. Copied contents of extract to C:\Program Files (x86)\XHorse Electronics\MCVI Driver for Toyota TIS\
4. Downloaded and installed the 64-bit registry hack (contents below - save text to file and name file with .reg extension, run to install via RegEdit)
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\PassThruSu pport.04.04]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\PassThruSu pport.04.04\XHorse - MVCI]
"Name"="XHorse - MVCI"
"Vendor"="XHorse ELECTRONICS Co.,Ltd."
"ConfigApplication"="C:\\Program Files (x86)\\XHorse Electronics\\MVCI Driver for TOYOTA TIS\\FirmwareUpdateTool.exe"
"FunctionLibrary"="C:\\Program Files (x86)\\XHorse Electronics\\MVCI Driver for TOYOTA TIS\\MVCI32.dll"
"APIVersion"="04.04"
"ProductVersion"="1.1.0"
"ProtocolsSupported"="J1850VPW:1, J1850PWM:1, CAN:1, ISO9141:1, ISO14230:1, ISO15765:1"
"J1850VPW"=dword:00000001
"J1850PWM"=dword:00000001
"ISO9141"=dword:00000001
"ISO14230"=dword:00000001
"CAN"=dword:00000001
"ISO15765"=dword:00000001
"SCI_A_ENGINE"=dword:00000000
"SCI_A_TRANS"=dword:00000000
"SCI_B_ENGINE"=dword:00000000
"SCI_B_TRANS"=dword:00000000
5. Rebooted tablet
6. Plugged in J2534 Mini-VCI cable. Windows 10 automatically detects the cable. You will notice in device manager it adds 3 devices:
Ports (COM & LPT) -> USB Serial Port (COM<n>) where <n> = a system assigned number
Universal Serial Bus Controllers -> USB Serial Converter
Vehicle Interface Module
Interestingly enough, Windows 10 installs the most up to date drivers for these devices. I tried to manually install the MVCI drivers from the MSI, no avail - on reboot, Windows 10 overwrites these.
Anyways, I don't think manually updating the drivers is necessary with the registry hack.
7. Loaded TechStream
8. In the menu, go to Setup -> VIM Select -> select Interface Setup = XHorse - MVCI
9. Turn vehicle to ON, position II
10. Select 'Connect to Vehicle' and you should be able to connect!
pdleung is offline
post #17 of 27 Old 09-08-2015, 01:15 AM
DIY Dad: if it has things, I'll tinker with it
SFCamry's Avatar
Quoted: 910 Post(s)
Sub
Camry Mod
THIS
'15 4Runner SR5 (1GR-FE)
'09 Camry SE 2.4L (2AZ-FE)
'97 Tacoma XL 4x4 Ext Cab 2.7L (3RZ-FE) - Manual
'97 Ford Explorer XLT V6 SOHC 4.0L 4x4
SFCamry is online now
post #18 of 27 Old 09-11-2015, 10:01 PM
Senior TN Member
Quoted: 105 Post(s)
May I ask what people who've posted in this thread are paying for Techstream and a cable?
The prices I see at techinfo.toyota.com are way out of my reach.
Thanks.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE
Mike Murrell is offline
post #19 of 27 Old 09-12-2015, 09:09 AM
Bill
Quoted: 24 Post(s)
I paid $26.99 for my cable from Amazon - of course, I knew it was a Chinese knockoff when I bought it. I believe it came with software, but that can be downloaded any number of places. One forum member strongly recommends the ALLSCANNER (cost some $80 on Amazon, I believe), I just haven't spent the money for that yet.
I got it to program a new key fob (push button start) - bought the fob (new oem - with emergency key) on ebay for some $80. Cost me $20 to get the emergency key cut locally. I believe others have spent less, but I'm not complaining.
Took me awhile to get the software and cable to work (Win 7 32 bit, probably all my fault), but it did work. Couldn't find any place (other than Toyota) in Oklahoma City to obtain a spare fob.
You know this, but.............................
Take care to try to purchase from a vendor on Ebay, Amazon or any other seller that will guarantee satisfaction or a refund for return.
Hope this helps
Bill
ranger0 is offline
post #20 of 27 Old 09-12-2015, 05:22 PM
Quoted: 1 Post(s)
Ive tried everything on my Windows 7 none of it works. tried the whole extraction, create directory method ive tried the version that with the cable V10.00.28 and also tried a downloaded V10.10.018. Also tried all 3 of those in virtual PC XP mode. Everytime i get an unable to connect to VIM error message.
KiloVictor is offline
post #21 of 27 Old 09-13-2015, 11:51 AM
Bill
Quoted: 24 Post(s)
KiloVictor -- Keep trying -
Best of luck
Bill
ranger0 is offline
post #22 of 27 Old 09-13-2015, 12:07 PM
Senior TN Member
Quoted: 105 Post(s)
KiloVictor:
Have you see this. I cannot attest to it as I've not even begun to work the Chinese Techstream. Just an FYI:
http://www.toyota-4runner.org/genera...-8-64-bit.html
post #23 of 27 Old 09-13-2015, 09:24 PM
SFCamry's Avatar
Quoted: 910 Post(s)
The problem seems to be the inability to run under an XP mode in some versions of Win 7. If you have Win 7 Pro you can download a plug-in that will allow you to run an XP mode, which will then work. Check out this link:
http://windows.microsoft.com/en-us/w...e-in-windows-7
Users with 8.1 64-bit have workarounds, but I have not seen any successful workarounds (yet) for Win 7 32-bit in versions not listed in the link above.
Camry Mod
THIS
post #24 of 27 Old 09-14-2015, 12:45 AM
This Space For Rent
humanoid's Avatar
Quoted: 561 Post(s)
Since I've upgraded to to Win10, wonder if any of these will still work?
humanoid is offline
post #25 of 27 Old 09-14-2015, 12:13 PM
SFCamry's Avatar
Quoted: 910 Post(s)
You may be able to run an XP environment in Win 10. I have not read thorough this, just did a fast Google, but you may want to check it out:
http://www.download3k.com/articles/H...-Hyper-V-00770
Or, the registry hacks may work as well. Considering the software and cable are less than $30 delivered, well worth it to try! It has saved my bacon, and others that have used it, on my XP laptop. I love it, and am desperate to make it work on a better system!
Camry Mod
THIS
The Following User Says Thank You to SFCamry For This Useful Post:
humanoid (09-14-2015)
post #26 of 27 Old 06-10-2017, 06:06 PM
Quoted: 5 Post(s)
Has anyone been recently able to get this to work on Windows 10?
I've got the drivers installed and when I plug in the ebay usb to OBD2 connector, the light is green on the connector.. BUt when I try to connect to the car.. I get error saying it can't connect to VIM.
I really need to get this working so I can program in a new TPMS sensor.
Thanks!
crabjoe is offline
post #27 of 27 Old 06-26-2017, 10:42 PM
Quoted: 90 Post(s)
Check the installation files and the installed files. One of the files with an extension ".dll" will be missing. Happened to me quite sometime back (unfortunately the laptop is away from me currently). Copy the file in or reinstall the software and it should work fine.
BTW, do you have 32-bit software or 64-bit software? If it is 32-bit then you need to amend the registry to get the software to work. Check out the thread and the post in particular - https://www.toyotanation.com/forum/12...l#post10516409.
I had originally installed TS on windows 7 64-bit machine and it continued working fine when I upgraded to Windows 10 64-bit. The software was 32-bit.
2004 Corolla LE 150K miles
2013 TCH LE 60K miles
rolla2004 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > General Discussion
User Tag List
Linear Mode Linear Mode
