1991 4WD Pickup 22r O2 sensor - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
 1Likes
  • 1 Post By Wekadog
post #1 of 8 Old 05-25-2019, 06:46 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Trying to replace my O2 sensor on my truck and want to know which sensor to buy, I can only find one in front of the cat. So my thought is upstream. Is there a difference? Thanks.
wesd is offline
post #2 of 8 Old 05-25-2019, 07:01 AM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 2089 Post(s)
Is the upstream sensor the bad one?
My Toyota List:
1982 Corolla SR-5 (Shell Right Now)
2005 Corolla CE 1ZZFE M/T
2005 Sequoia Limited 2UZFE A/T
2008 LS460 SWB RWD 1URFSE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is offline
post #3 of 8 Old 05-25-2019, 12:04 PM
Quoted: 45 Post(s)
The terminology "upstream" and "downstream" usually apply to fuel injected systems. The difference between them is just the length of the cable. Since your 22R is carbureted, it only has the upstream one.
Wekadog is offline
post #4 of 8 Old 05-26-2019, 07:15 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
It's actually the only one I can see.
wesd is offline
post #5 of 8 Old 05-26-2019, 07:16 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
My 91 is fuel injected but I can only find one sensor and it is in front of the cat. I don't have a carburetor.
wesd is offline
post #6 of 8 Old 05-26-2019, 07:24 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
So just to update anyone who can help me. I looked up on the Denso website yesterday and found the part 234-4055. My new question is there are two different 4055's shown, one being the upstream exc California and the other being downstream California. Are they the same part since they are the same part number? I just want to order the right part so I don't waste time trying to figure things out if it doesn't work. Thanks for reaching out guys with feedback as I'm new to this.
wesd is offline
post #7 of 8 Old 05-26-2019, 09:34 PM
Quoted: 45 Post(s)
First off, I seriously doubt you have a fuel injected 22R. All 22Rs are carbureted. Are you sure you don't have a 22RE? If you're looking up parts for the wrong engine, you can't expect to get the right part.
Also, you should look at the information plate under the hood and see if yours is a California model. You'll see on the labels below that one says CAL and the other says FED.
If yours is a California 22RE and you're replacing the upstream sensor, the part number is 4056. If it's a Fed 22RE, the upstream sensor is the 4055. Yes, both listings for the 4055 are the same part. They're just calling out different applications.
If there's any question in your mind, look at the connector, the number of wires and the length of the wires.
As a side note, don't get talked into a threaded sensor with an adaptor plate. They don't always fit without modifications. The Denso models you're looking at should be a good fit.
sdspeed likes this.
Wekadog is offline
post #8 of 8 Old 05-28-2019, 08:31 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Many thanks my friend now I know what to look for. You are correct it is the 22re.Thanks for the quick reply. I was hoping if the part number was the same it wouldn't make a difference since it did show it was for upstream and downstream replacement.That said I'll order the part and get the replacement done.
wesd is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
