92 22re horrible rattle - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 4 Old 05-30-2014, 10:59 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ok, so my 92 2wd 22re 5-speed has came down with a case of the rattles. It is pretty bad at an idle and goes away at highway speeds only to return under a load or at idle. I had the timing chain, guides, oil pump, and water pump replaced two years ago. I haven't adjusted the valves since they were adjusted with the new tc. the truck has 340,000 on it but still runs like a champ. Any help would be appreciated, I would rather start simple in hope of a cheap easy fix. I'm taking off the water pump belt to see if that changes anything and then a/c and smog belt. Sounds like its in the front/top of the motor.
GREENYODA92 is offline
post #2 of 4 Old 05-31-2014, 10:18 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Checked it with a broom stick and my ear, its coming from the front of the motor.
Could possibly be the bearing in the water pump but I'm betting on the tc guides.
smh.. should've bought the metal ones. I will update more when I get further along so maybe, I CAN HELP SOMEONE WITH THEIR PROBLEM IN THE FUTURE.
post #3 of 4 Old 06-01-2014, 09:00 AM
Soylent Green sales
fourwd1's Avatar
Quoted: 560 Post(s)
Let us know how it goes, problems like that can be hard to figure out.
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
The Following User Says Thank You to fourwd1 For This Useful Post:
GREENYODA92 (06-04-2014)
post #4 of 4 Old 06-04-2014, 01:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Tore the valve cover off and.... timing chain guide on driver side has disappeared.
I replaced the chain, guides, oil pump and water pump three years ago. I've had a slight rattle the last year or so, Im assuming the plastic guides didn't hold up as long as I had thought. Moral of the story: spend the extra $, buy the timing chain kit with metal guides or throw time/money away every 70,000 miles.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
