Removing backing plate rust and repainting question - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
 1Likes
  • 1 Post By 71Corolla
post #1 of 4 Old 06-18-2019, 05:02 PM Thread Starter
Wanna Fix It!
John Anthony's Avatar
Quoted: 682 Post(s)
(Thread Starter)
Will be replacing the rear brakes on my 1987 base pickup. The backing plates are rusty and almost all the paint has peeled off due to a long time brake fluid leak coming from the wheel cylinder. I have all the parts (Toyota shoes, Advics wheel cylinders, Raybestos drums, and Raybestos hardware/adjuster). Two questions:
1. What's the best way to remove the surface rust on the backing plates? I was going to just buy some 180 grit waterproof sandpaper, but don't know if that's the best grit or if some other method of rust removal is better.
2. I want to do a quick spray paint job on the backing plates after removing the surface rust. I'm not wanting to remove the backing plates, so I just want to do a simple job here. I just want to get a spray can from Lowe's or Home Depot and would like advice on what would be a good paint to get and also if it should be flat, or satin, or what kind of gloss ?
In my earlier thread about the axle noise I was hearing, I posted a very short video which does show the surface rust on the backing plate if that helps you to see what it looks like:
Thanks for any advice.
2004 Corolla LE 375K+ miles.
1987 Toyota Pickup base, 4spd 162K+ miles.
1996 Toyota Camry LE I4 (son's car) 230K+ kilometers.
2010 Toyota Camry LE I4 (mother's car). 162K+ miles.
"There's always free cheese in a mousetrap."
John Anthony is offline
post #2 of 4 Old 06-18-2019, 05:34 PM
Toyota Collector
71Corolla's Avatar
Quoted: 2453 Post(s)
Forget abrasion soak the plate in Evapo-Rust for 2-3 days it will come out pristine, zero rust. Then clean and paint if you use something like Rust Bullet it will be impervious to chemicals including brake fluid. BTW Evapo-Rust will remove loose paint, or sometimes all of it in my experience.
sdspeed likes this.
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is offline
The Following User Says Thank You to 71Corolla For This Useful Post:
John Anthony (06-19-2019)
post #3 of 4 Old 06-19-2019, 09:43 AM Thread Starter
Wanna Fix It!
Quoted: 682 Post(s)
(Thread Starter)
Thank you for responding. Since I don't want to remove the backing plate, I can't really soak it in Evapo-Rust. Won't it drip right off if I brush it on the vertical surface of the backing plate? What about the Evapo-Rust Gel, which claims to work on vertical surfaces? The E-R Gel claims it only needs two hours to work----don't know if that's really true. If it is, it must be some nasty stuff, but interestingly enough the product information claims it is harmless/non-caustic. Have you ever used E-R Gel before?
post #4 of 4 Old 06-19-2019, 04:21 PM
Senior TN Member
Quoted: 230 Post(s)
Get a stiff wire brush and go for it. Paint it with something like this. Done.
https://www.eastwood.com/eastwood-ru...SABEgJYRPD_BwE
chuckoff is online now
The Following User Says Thank You to chuckoff For This Useful Post:
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
