'02 Highlander Sitting Lower in Rear - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 1st Generation (2001-2007) Forum dedicated to the discussion of 1st generation Toyota Highlanders.
 1Likes
  • 1 Post By toofazt
post #1 of 6 Old 04-18-2019, 10:21 AM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
My 2002 Highlander is sitting about 1" lower in the rear compared to the front. Is this a normal stance or is it time for new struts/springs?
Andrew Rivlin likes this.
toofazt is offline
post #2 of 6 Old 04-18-2019, 10:53 AM
Quoted: 3 Post(s)
My 03 has a lot of rear sag on bumps, but doesn't sit lower while stopped or on flats. What I did notice is massive wear on my rear tires, the front looks fine.
I wonder too. 109k, new tires @ 90,000
Sent from my Pixel 2 XL using Tapatalk
Andrew Rivlin is offline
post #3 of 6 Old 04-18-2019, 10:58 AM
C R
C R's Avatar
Quoted: 4 Post(s)
How did you measure it? Which engine? I’ll measure mine to compare. I changed mine out last year
C R is offline
post #4 of 6 Old 04-18-2019, 12:39 PM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Originally Posted by C R View Post
How did you measure it? Which engine? Iíll measure mine to compare. I changed mine out last year
Measured from the outside edge of wheel well to edge of 16" rim. Front: 9-1/4", Rear: 8-1/4". V6 engine.
toofazt is offline
post #5 of 6 Old 04-19-2019, 04:36 PM
C R
C R's Avatar
Quoted: 4 Post(s)
Here are the measurements I got-
2001 4 cyl FWD base / 5 seat w/ tow 16 in wheels full tank
Front: 9.0 in. Rear: 8 5/8
2005 V6 AWD Limited / 7 seat w/ tow. 17 in wheel 1/4 tank
Front 8 5/8. Rear 8 1/2.
C R is offline
post #6 of 6 Old 04-20-2019, 06:44 AM
Quoted: 27 Post(s)
when I did my struts the highlander sat noticeably higher, then settled a bit after a few months, so new struts can definitely change the stance. I used complete assembled units, new springs and all.
You might want to check out hayabusafalcon's thread on strut replacements, there's tons of good info from lots of people that should tell you what you need to know.
Mgeorge is online now
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 1st Generation (2001-2007)
User Tag List
Linear Mode Linear Mode
