I JUST want to get the arm rest... - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 6th Gen - Hybrid (2007-2011) Toyota Camry Hybrid Discussion for years 2007-2011.
post #1 of 2 Old 04-15-2019, 06:12 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Look, this isn't complicated, but every place I go to: dealership, online, wherever!!! They want to sell the ENTIRE DOOR PANEL, ranging from $600-$1,000!!! I have two front door armrest pieces that are worn (see the tear on the passenger side?) and I JUST want the armrest piece, NOT THE WHOLE DOOR PANEL!!! I don't have $1,500 to blow on two door panels just because the armrest is sunk in... -_- tips, anybody?
2008 Toyota Camry Hybrid over 200K miles, gray interior (trim code LA13)
Click image for larger version
ID:	238070   Click image for larger version
Last edited by Allen1350; 04-15-2019 at 06:19 PM. Reason: Forgot to put in car specs
Allen1350 is offline
post #2 of 2 Old 04-16-2019, 11:28 AM
Moderator
ukrkoz's Avatar
Quoted: 759 Post(s)
1. tough one. Locate salvage yard part that matches. It's tough cuz you have to have exact color match.
2. not as tough pending DIY skill or availability of professional.
Take the door panel off. It's not that hard. See, if you can remove just that piece. I am positive, panel has various components that are glued/riveted/else together. Remove that piece and re-upholster it. If you do both same end panels, it will look designed so, but you have to do both left and right ones. For color match. There's plenty of soft padded grey thin vinyls available in hobby stores. Even thin leathers. It's just that leather you'll have to add padding and that's when it starts getting tricky on gluing it all together. But will look and last better.
ukrkoz is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Camry Hybrid > Camry 6th Gen - Hybrid (2007-2011)
User Tag List
Linear Mode Linear Mode
