2011 hybrid camry stalls - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 6th Gen - Hybrid (2007-2011) Toyota Camry Hybrid Discussion for years 2007-2011.
post #1 of 3 Old 05-17-2019, 04:38 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi I’m new here, my toyota camry i just bought 6 months ago with 250k
The seller told me that the hybrid Battery Pack is bad , but he said whenever the warning lights come on just plug a generic obd2 scanner he supplied and clear the codes
I was doing this for a while , the car drives normal with lower 30s mpg untill last week the warnig lights will come on followed by loss of power and the car stalls , and after i clear the code it does it again in feww minutes
My question is : does a bad hybrid battery cause the camry to stall ?
I’m sure the hybrid battery is bad But is this what causing the stall or not ?
I don’t want to spend 1500$ on a rebuild battery to discover that there’s a different issues with the car
Click image for larger version
Fouda is offline
post #2 of 3 Old 05-18-2019, 08:50 AM
Moderator
ukrkoz's Avatar
Quoted: 830 Post(s)
Welcome to the forum.
https://www.google.com/search?source...31.3qdT9E9aYKM
Read. Lots of info and choices to make there. Though if you knew that hybrid battery was bad when you bought it - it's likely battery, as connection between wheels and engine is done via electric motor, so bad battery equals loss of motive force.
ukrkoz is online now
post #3 of 3 Old 05-18-2019, 04:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi i found a cure from a very expert person on hybrid cars
What i had was code p3190
And code p0A080
Symptoms are : chs warning light shortly after all lights on and los of power
The amswer to this particular condition is replacing the Fuse box Relay controle Module that wont fix the battery but the car won’t stall any more
Fouda is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Camry Hybrid > Camry 6th Gen - Hybrid (2007-2011)
User Tag List
Linear Mode Linear Mode
