1st oil change - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 12th Gen (Hatch 2019+/Sedan 2020+) Forums dedicated to the 12th generation Toyota Corolla
 29Likes
post #1 of 131 Old 08-25-2018, 01:10 AM Thread Starter
19 Corolla HB SE 6-spd
Quoted: 1059 Post(s)
(Thread Starter)
Arrow 1st oil change
Toyota recommends doing the first oil change at 16,000 kms (10,000 miles), then every 16,000 kms (10,000 miles)… I just drained the original 0W-16 now at 1,000 kms (621 miles). It came out incredibly thin, like alcohol. I don't like how it then splatters small droplets around the drain pan. It did have a very peculiar fuel dilution smell.
A larger oil filter cannot be used, as the filter mount is not machined any wider than it has to be for oem sized filter. I was only surprised to see the original oil filter was made in China.
I had to drive it up on blocks to use a jack. It'll be much easier driving it up on ramps. Oil filter and drain plug are well accessible after removing 4 screws securing the cover, with a 10mm socket and ratchet... I'm changing it with Valvoline synthetic 0W-20. It took 4.55 liters (4.8 US quarts) to refill instead of 4.3, changing the oil without replacing the oil filter.
Valvoline Advanced Full Synthetic ILSAC Grades (except 0W-16) meet the newly adopted API SN PLUS classification, protecting GDI (Gasoline Direct Injection) engines from low-speed pre-ignition (LSPI).
https://www.valvoline.com/our-produc...etic-motor-oil
https://sharena21.springcm.com/Publi...2-ac162d889bd1
Toyota oil filter # 90915-YZZF2
invader is offline
The Following User Says Thank You to invader For This Useful Post:
Leo MalagueƱo (11-23-2018)
post #2 of 131 Old 08-25-2018, 04:41 AM Thread Starter
(Thread Starter)
Thumbs up
More photos underneath. Parts of the bottom panels, etc, are sticky from the Ziebart oil guard rust proofing:
invader is offline
post #3 of 131 Old 08-26-2018, 01:03 AM
dchev
dchev's Avatar
Quoted: 9 Post(s)
Oil and filter
You can get Toyota Oil 0W16 for $6.51 per bottle and filter for $5.86 from your Toyota Dealer. I believe that they will give you a 15% discount if you buy one case of oil (6 bottles).
Filter is made in China, but keep in mind that this country produces as many vehicles as USA, so quality should be okay.
It is nice to see how well isolated the under body of the car is!
dchev is offline
post #4 of 131 Old 08-26-2018, 03:43 PM
Quoted: 10 Post(s)
I'm glad you posted this, looks like I can keep buying the same filters for my 9th gen and whenever I decide to finally buy the new hatch lol
Frankfp3 is offline
post #5 of 131 Old 08-26-2018, 04:30 PM
Senior TN Member
cb91710's Avatar
Quoted: 1586 Post(s)
Originally Posted by invader View Post
Toyota recommends doing the first oil change at 16,000 kms (10,000 miles), then every 32,000 kms (20,000 miles)
I'm looking at the '19 Hatchback manual now and it is the same as the '16 Corolla and the '18 iM.
Change oil at 10,000, 20,000, 30,000, etc....
https://www.toyota.com/t3Portal/docu...aHatchback.pdf
-- Rich
cb91710 is offline
post #6 of 131 Old 08-26-2018, 05:06 PM Thread Starter
(Thread Starter)
https://www.toyota.ca/toyota/en/my-t...nance-schedule
No maintenance guide book is provided in Canada.
invader is offline
post #7 of 131 Old 08-26-2018, 05:43 PM
Senior TN Member
Quoted: 720 Post(s)
At 16,000 kms (10,000 miles), then every 32,000 kms (20,000 miles) in the Canadian site:
If you look carefully, an oil change is part of Service #2 and Service #3 . Combined, that means once every 16K km (10K miles).
cb91710 likes this.
mark888 is offline
post #8 of 131 Old 08-26-2018, 08:49 PM Thread Starter
(Thread Starter)
Okay, that makes sense. I hadn't noticed Service # 3.
It took 4.55 liters (4.8 US quarts) to refill instead of 4.3, changing the oil without replacing the oil filter... I'll probably change oil and filter (4.6 liters) at 8,000 kms, then every 8,000 kms (5,000 miles).
invader is offline
post #9 of 131 Old 08-26-2018, 09:56 PM
Senior TN Member
cb91710's Avatar
It's really overkill, but it's your car, your wallet, and your choice.
-- Rich
cb91710 is offline
post #10 of 131 Old 08-26-2018, 10:18 PM Thread Starter
(Thread Starter)
I'll see what it looks like after 7,000 kms at 8,000 kms on the odometer... Every 8,000 kms was well enough with the 1ZZ-FE for my type of severe service in dusty and Canadian extreme weather conditions.
invader is offline
post #11 of 131 Old 08-26-2018, 10:22 PM
uh..no, it's not a hybrid
LeanBurn's Avatar
Quoted: 188 Post(s)
Canada
Fuel dilution smell? This begs for a used oil analysis IMO.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.111L/100km(38.761mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline
post #12 of 131 Old 08-26-2018, 10:31 PM Thread Starter
(Thread Starter)
Some fuel dilution, increased contamination levels, and some viscosity breakdown are to be expected from the original oil upon normal engine break-in... It will nonetheless be interesting to see when someone does produce a UOA from the M20A-FKS engine with D-4S fuel-injection system.
invader is offline
post #13 of 131 Old 08-26-2018, 11:31 PM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1963 Post(s)
iTrader Score: 8 reviews
This is why I always change my oil at 1k miles on any new car. I've always believed that it's a good thing to do and can be done for under $30.
89 Supercharged White MR2 5MT/09 Corolla S TURBO CSM 5MT
17 Corolla iM CSM 6MT/ 17 RAV4 XLE MGM
95 Previa S/C White AT/06 Scion xB MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
post #14 of 131 Old 12-05-2018, 01:40 AM Thread Starter
(Thread Starter)
2nd oil change at 4,350 miles (7,000 kms) with filter change. That's 6,000 kms since 1st oil change at 1,000 without changing filter, and it was well due... It took 4.7 liters (4.97 US quarts) instead of 4.6 (4.86 US quarts) to be at the full mark.
This time with Mobil 1 Extended Performace 0W-20 and Denso 1502000 FTF oil filter.
invader is offline
post #15 of 131 Old 12-05-2018, 02:23 AM
Quoted: 102 Post(s)
I was going to say the same thing. Break in oil is never a good indication of what's going on.
Desy is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 12th Gen (Hatch 2019+/Sedan 2020+)
User Tag List
Linear Mode Linear Mode
