2014 TAH Died Today 94k on odometer - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 4th Gen - Hybrid (XX40/2012-2018) Toyota Avalon Hybrid discussion for years 2012-2018.
 1Likes
  • 1 Post By ukrkoz
post #1 of 15 Old 02-07-2019, 07:21 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Started after pushing engine hard in Sports mode. Engine sounded like it didn't have any oil or as if oil pump wasn't working. Limped 18 miles home and 3 mechanic shops here in NYC say the engine is shot! Drove it home and tried to start it to take it to the dealership but it stalled 50 feet from home.
How hard is it to pull the engine out of our cars?
Any help is greatly appreciated!
Happiegolucky is offline
post #2 of 15 Old 02-08-2019, 08:18 AM
Quoted: 174 Post(s)
Happy...not so lucky...: I have no knowledge of R&R of the ICE, but...your post begs more details. Exactly what aspect of the engine failed? Catastrophic oil failure? Are you the original owner? Maintained by the book? Driving history of the car?
(I'm at 85k miles, still smooth as silk, no issues since I bought it 2.5 years ago with 12k on the clock. DFW region, mostly highway miles.)
2014 AvalonHybrid Limited
2015 Nissan Leaf S
2013 Ford CMax SEL
2017 Ford Fusion Energi Titanium
pianewman is offline
post #3 of 15 Old 02-08-2019, 12:10 PM
Moderator
ukrkoz's Avatar
Quoted: 862 Post(s)
If it's a 4 cylinder engine, remove head, remove oil pan, drop connecting rods lower section down and push pistons with rods up and out. Replace rings and crankshaft bearings. Done. It's about 6-7 hr DIY job. Replace all gaskets same time, of course. As you mess with timing chain, replace tensioner and idler. It will be like a new engine. Toyota had major oil consumption issue with Camry engines, they came up with improved pistons... might not be a bad idea to do them too. That's if you do not want to take risks with used engine. Or, remove current one.
Happiegolucky likes this.
ukrkoz is offline
post #4 of 15 Old 02-08-2019, 04:05 PM
Quoted: 174 Post(s)
Thanks, ukrkoz, for the reasonably detailed instructions.
We still don't know WHAT failed, though! "...engine is shot!..." needs clarification, especially on an engine with only 94k miles on it.
2015 Nissan Leaf S
2013 Ford CMax SEL
post #5 of 15 Old 02-09-2019, 08:49 AM
Moderator
ukrkoz's Avatar
Quoted: 862 Post(s)
If you ran down on oil, it likely seized. That is normally crankshaft bearings.
But indeed, we do not know. Just a guess.
ukrkoz is offline
post #6 of 15 Old 02-10-2019, 05:17 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I bought the car mid august 2018 with 92k on odometer from a dealership in MA. He didn't have the maintenance records but it was a good deal at $13,500 IMHO. No so much anymore, SMH. Oil was about 1 1/2 quarts low. I"m still not sure exactly what the cause is but 3 local mechanics said its internal and engine is bad. None opened engine up to diagnose it further but had it scanned with advanced scan tool and it had no codes. Is there a DIY engine removal anywhere?
I found a used engine for $400 locally but I have to pull the engine myself. Does anyone know where I can buy the workshop manual for 2014 Toyota Avalon Hybrid?
post #7 of 15 Old 02-12-2019, 04:45 PM
My first Hybrid
Quoted: 8 Post(s)
Engine failure..at this mileage.. Bad luck..
May be it was low in oil (pump failed) and driving miles damaged it more? Just a wild guess..
saneesh81 is offline
post #8 of 15 Old 02-16-2019, 11:57 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
My question now is how involved is it to pull the engine. I have been looking everywhere for a workshop manual for our cars (TAH 2013-2018) but have not found one anywhere for purchase. Nor can I find a DIY engine removal/installation guide. Planning on removing the engine this Tuesday Feb. 19, 2019, so any help/links/guidance would be greatly appreciated. I have done this on a few cars over the years but all with help, this time I am doing it SOLO. I am a little scared of the hybrid system since I heard it can kill you from the high voltage. I already borrowed tan engine hoist from a friend and am gathering as much info as I can prior to doing the job..
Thank you all for the help
post #9 of 15 Old 02-17-2019, 09:05 AM
Moderator
ukrkoz's Avatar
Quoted: 862 Post(s)
Regular Avalon manual will serve you well as, in principles, it's same engine. Hybrid battery has kill switch that de powers any energy flow to the inverter.
Read this first:
https://www.manualslib.com/manual/11...page=16#manual
as it has clear instructions on how to avoid any high voltage hazard.
I still say it's easier and simpler to remove head and drop pistons down. You do not have to pull everything out and damage PSD in the process. Power Split Device, what is your transmission.
Do you actually know for sure, what is wrong with the engine? To warrant such effort?
ukrkoz is offline
post #10 of 15 Old 02-17-2019, 09:12 AM
Moderator
ukrkoz's Avatar
Quoted: 862 Post(s)
For those who will be helping this poster - REMINDER not to post any Toyota manuals in the forum. It is against forum rules.
17. There will be no posts or threads containing a direct link to Toyota Factory Service Manuals. All threads regarding any copyrighted Toyota material (ie., Entune, Techstream, Techstream Lite, etc.) will be deleted, and Forum Administrators/Moderators reserve the right to determine what material is copyrighted or not. First offense will result in a warning, second a temporary ban, third a permanent ban. Click here to read more about this policy, particularly if you consider it unfair. Links to pirated software of any kind will not be tolerated either.
Thank you.
ukrkoz is offline
post #11 of 15 Old 03-25-2019, 06:24 PM
Quoted: 3 Post(s)
I am sorry to hear this. I am new here, and am in the market for a 2014 TAH myself. I was just looking at one with 125k miles on it for 12,500, which I am assuming is a good deal, but your story scares me. I drive a lot for work, and would hate to have to replace an engine immediately.
ToyotaHybrid4Me is offline
post #12 of 15 Old 03-26-2019, 10:33 AM
My first Hybrid
Quoted: 8 Post(s)
Wonder what actually broke the engine. At 92K, it must have been really neglected.
post #13 of 15 Old 03-27-2019, 08:00 AM
Quoted: 174 Post(s)
If your work requires your timely presence, I'd think a newer car with fewer miles would be preferable. Auto breakdowns can kill your employability in a hurry.
2015 Nissan Leaf S
2013 Ford CMax SEL
post #14 of 15 Old 03-27-2019, 09:14 AM
Quoted: 3 Post(s)
Sounds like you are implying the TAH is unreliable?
post #15 of 15 Old 03-27-2019, 02:38 PM
Quoted: 174 Post(s)
Not at all. I totally trust my 2014 TAH, because I KNOW the car, it shows zero signs of issues, or impending issues. It is our road-trip cruiser.
Any car, at 120k miles, driven by ????, maintained by ???? I wouldn't want to stake my job on it, regardless of the model. There are just too many unknown factors, in my opinion. The TAH is incredibly complex, with complex electronics, and if it hasn't been taken care of properly, might (might!) have issues.
If your job depends on day-after-day auto reliability, your odds go up if it's YOUR car from new, IF you know how to maintain it, and can be proactive about weak areas.
...my opinion, of course...
2015 Nissan Leaf S
2013 Ford CMax SEL
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Avalon Hybrid > Avalon 4th Gen - Hybrid (XX40/2012-2018)
User Tag List
Linear Mode Linear Mode
