1 - 7 of 7 Posts
R
Guest
My son recently took the car off to college and he called to tell me
that when he applies the brake the dash lights come on. He also found
out that at night when turns on the park or headlights, his brake
lights including the factory installed spoiler light (eye level brake
light) is always illuminated. While bringing the car home at night,
he found that the cruise was not working. We tried the cruise during
the day without the lights on and the cruise worked fine. The four
way emergency flashers have no effect on the issue and work properly.
We have talked with several Toyota people and they have gone from the
Main Control Module to a switch in the sterring column. Is there
anyone out there familiar with this problem on this vehicle? Your
help will be greatly appreciated. :?:
Posted at author's request, using http://www.AutoBoardz.com interface
Articles individually verified to usenet standards. Visit URL to contact author/report abuse
Thread archive: http://www.AutoBoardz.com/97-DX-lighting-problems-ftopict204011.html
R
Guest
Discussion Starter #2
Re: '97 Corolla DX lighting problems
"regstaylor" <[email protected]> wrote in message
news:[email protected]
I'm not sure what the Toyota people mean by "Main Control Module" as there
are not modules in the car referred to by that nomenclature. If they are
talking about the engine electronic control module, I doubt if that is the
problem because there is no connection with headlights.
The odd combination of problems points to either a bad ground, shorted wire,
or bad combination switch in the steering column.
If you are going tot look for a bad ground or shorted wire, start by looking
at any aftermarket accessories like keyless entry systems, remote starters,
fog lights, audio systems, and Ipod adapters because poor installation of
those accessories is a common cause of odd problems. Check to make sure the
ground wires for the rear lights are making good connection with body
ground. Any body repairs in the area may prevent a good ground.
Also check the wires to the center high mounted stop lamp (CHMSL) on the
spoiler and make sure they are not cut, chafed, or crimped, especially where
it follows the hinge and connects to the wiring harness.
You will need an electrical wiring diagram and a volt/ohm meter to properly
diagnose the combination (headlight, turn signal, and windshield wiper)
Ray O
Guest
Re: =?iso-8859-1?b?kjk3?= Corolla DX lighting problems
On Fri, 26 Jan 2007 04:25:26 +0000, regstaylor wrote:
> My son recently took the car off to college and he called to tell me that
> when he applies the brake the dash lights come on. He also found out that
> at night when turns on the park or headlights, his brake lights including
> the factory installed spoiler light (eye level brake light) is always
> illuminated. While bringing the car home at night, he found that the
> cruise was not working. We tried the cruise during the day without the
> lights on and the cruise worked fine. The four way emergency flashers
> have no effect on the issue and work properly. We have talked with several
> Toyota people and they have gone from the Main Control Module to a switch
> in the sterring column. Is there anyone out there familiar with this
> problem on this vehicle? Your help will be greatly appreciated. :?:
Hmmm....I'd be looking at the brake light switch to begin with, and (Good
Luck!) a ground problem.
Guest
>> out that at night when turns on the park or headlights, his brake lights
>> including the factory installed spoiler light (eye level brake light) is
>> always illuminated. While bringing the car home at night, he found that
>> the cruise was not working. We tried the cruise during the day without
>> the lights on and the cruise worked fine. The four way emergency
>> flashers have no effect on the issue and work properly. We have talked
>> with several Toyota people and they have gone from the Main Control
>> Module to a switch in the sterring column. Is there anyone out there
>> familiar with this problem on this vehicle? Your help will be greatly
>> appreciated. :?:
I think they may be referring to the 'relay integration module', what I
consider to be a horrible abomination, since it contains the buzzer, a
number of relays, the windshield wiper INT timer, etc. So, if one function
goes out, instead of replacing a $7 item, you get to shell out $135 for a
new module!
Not one of my favorite Toyota 'innovations'...
> wire, or bad combination switch in the steering column.
> looking at any aftermarket accessories like keyless entry systems, remote
> starters, fog lights, audio systems, and Ipod adapters because poor
> installation of those accessories is a common cause of odd problems.
> Check to make sure the ground wires for the rear lights are making good
> connection with body ground. Any body repairs in the area may prevent a
> good ground.
> where it follows the hinge and connects to the wiring harness.
> properly diagnose the combination (headlight, turn signal, and windshield
> wiper) switch in the steering column.
Guest
>> function goes out, instead of replacing a $7 item, you get to shell out
>> $135 for a new module!
> honda's done that too, called a "multiplex" box or something. the good
> thing is theyre extremely reliable, and mean less subassemblies to buzz,
> rattle, and break.
True...but when they do break, it's bad news.
G
Guest
Discussion Starter #6
Re: =?windows-1252?Q?=9297_Corolla_DX_lighting_problems?=
Assuming this all happened at the same time, it smells suspiciously like
a grounding issue. Check the cable from the battery to ground and make
sure BOTH ends are well connected. Second, take another look at the
light switch. It might have failed.
S
Guest
Discussion Starter #7
I had a similar problem with my wife's 97, but only on one side.
Ended up being bad solder in the sockets. I took the easy way out and
replaced that cable assembly.
It may be the same idiot worked on both your cable assemblies...
Scott in Florida
'Let every nation know, whether it
wishes us well or ill, that we shall
pay any price, bear any burden,
meet any hardship, support any friend,
oppose any foe to assure the survival
and the success of liberty.'
John F. Kennedy
1 - 7 of 7 Posts
