ok anyone have this problem. about three months ago the battery light started flashing intermittently. then it starting staying on for some period of time. when i gunned the engine it would go off. well, the battery is new and the alternator tested fine, and the the first dealer i took it to said the alt belt just needed tightening. i got the car from the dealer, and a day later it started doing the same thing. i took it to a second dealer and after a thousand dollers later they said the a wiring harness had to be changed. i took the car from the second dealer, and a day or so later the battery light started flashing again. i took it back and demanded that they find the problem and give me a car to use. this time they said a tsb had been found about the wiring harness for the alternator, and they fixed it without any charge. two days after i got the carback the problem started up again. it seems worse when i start up the car after it has been sitting out over night. the battery light blinds for a few seconds and goes off. it does this intermittently. so far the problem has not run down my battery, but is it very irritating. does anyone haven suggestions????
