I have a 2003 Toyota Camry XLE that has had the following issues.
1) When going over speed bumps you can hear a very loud creaking in the front and rear and occasionally a clunk in the rear.
2) When driving on rough or bumpy roads you can hear a metallic chattering coming from the driver's side.
3) There is a vibration in the car that I can't pinpoint but I was told the front rotors are slightly warped and that could be causing it, thoughts?
4) I put brand new tires on in January and it has less than 10,000 miles on them but they already look like they need to be replaced. They are Michelin Hydro-edge tires. I have had it balanced/rotated at 6,000 miles as well as an alignment. Nothing was said to me about any problems by the tire place when I had it done a few months back, which I find odd.
5) When turning into parking spots or turning at low-speed in general, especially when turning right, I sometimes hear the tires squealing.
I was going to go ahead and replace all 4 struts, strut mounts, strut boots, rear sway bars, all 4 rotors and brake pads. But I wanted to make sure that this would fix the problem.
Do I need to get the front Driver/Passenger CV Half Shaft Drive Axle assemblies?
Are there any other parts that need to be replaced that could fix the issue? (Tie Rods? Ball Joints? etc?)
Are there any other parts you'd recommend replacing while working on the car?
I tried searching but could not find anything that specifically matched the problems.
Any help would be appreciated.
Thanks!
