1 - 12 of 12 Posts
Does anyone know where I can get some descent eyelids for my '04 corolla?
P.S. Not the one's that go around the headlight, just on top of the headlight.
Thanx
The easiest way is to buy the headlight covers and cut and file them to your desired shape. The advantage of these is that they are already designed to fit and mount to your car. I works great. If you want to paint them to match, make sure you rough them up with sandpaper first.
ldpantoja said:
DVS, may I please have some DIY specs on how to make the vinyl ones??
http://www.cardomain.com/memberpage/443686
Yeah, just like what falnfenix said. Carefully lay a large enough piece of vinyl over the headlight, mark the line(s) you want to cut, then use a razor to cut it. Don't press down on the razor too hard to the point where you'll scratch the headlight.
TOcorolla said:
hey how did you get the clear corners? was it factory?
Here's the DIY - http://www.corollatoys.com/diy/9thGen/2.htm
Discussion Starter · #11 ·
You gonna need to either bake the headlight or use screwdriver or knife and plyers to take it out. I did it with screwdriver and plyers. It was hard, but it looks good.
1 - 12 of 12 Posts
