1 - 4 of 4 Posts
My 03 corolla would idle pretty low when coming to a redlight. Normally on a car it idles 600 to 800rpm depending on the car but my corolla seems to drop to about 500rpm and then back to like 700 800rpm in like 3 seconds. Even at 700rpm in gear the car still vibrates and shakes a lot. Probably motor mounts are going bad.
I thought my MAF sensor was bad or covered in oil considering I use to use K&N drop in filter. I brought a new sensor from the dealer for $170 and the idle issue is still there. Next thing I did was clean out the throttle body. Sprayed carb cleaner and cleaned it up for a while. A lot of carbon buildup in there. I thought that would solve the probably but nope. Idle would still drop really low.
The car has 70k miles on it now and has been well maintained. I do all the maintance work on the car myself. My next guess would maybe be a clogged EGR passage.
i feel your pain man im having the same problem 65k on the clock 05 i cleaned the throttle body too and put a new air filter for good measure still the same its only like that 2 months so I'm thinking it has to be a sensor or a air leak throttle body was not to dirty but i didn't spray into iac valve did you.i didn't want to damage it i used wynns injector and carb cleaner to clean the t/b if i find out what it is ill post it up here let me know if you find out yourself..good luck mate
2005 Corolla
The intake manifold gaskets are a fairly common problem for the 2003-08 1zzfe corolla. I would replace the intake manifold gasket as you may have a slight vacuum leak causing your issues, it is a very cheap DIY repair.
Matrix XR 2003
agreed
also look into cleaning the IACV, if you cleaned the throttle body some of that residue gunk may have fallen unto the IACV.
1 - 4 of 4 Posts
