1 - 4 of 4 Posts
Hey guys,
Could really use a hand here :|
I'm trying to do the clutch on my echo, HOWEVER i cant get these clips off the cables for the life of me. any suggestions?
I cant find anyone documenting the process on an echo at all.
They just slide off, like e-clips.
It's hard to explain, but basically, you need to pull them straight up, away from the cable. You can get a pair of pliers on the lip of the clip and give it a side-to-side wiggle as you pull, they'll pop right off.
They're only held in place with Friction.
The clips ended up spinning to one end and pulling right out! 😂
I was able to get the trans dropped shorty after, thanks!
1 - 4 of 4 Posts
