It should be passive, the headunit only outputs 4 channels (as does the amp). The JBL system is an 8 speaker system (rear coxials count as 2 each).
The headunit is probably what is applying the OEM EQ to the system you are complaining about. A new headunit might help with that. One thing about the power. You likely won't get 20watts out of an aftermarket unit. Usually its closer to 15 a full tilt. Look at the CEA certification not the manufacturers rating. For example, Pioneer lists their units at 20 watts, but they are rated at (under CEA's testings) 14 watts. Having said that, the OEM amp is probably 20-25 watts each channel.
I personally would try to keep the OEM amp.If you want to bypass it, you will likely have to run new speaker wire to the headunit.
