Hey all,
Ever since two years back when I got my '04 Camry from my parents there has been a particular water problem in the rear right passenger seat. For some odd reason water magically puddles underneath only that half of the rear bench and the other half (rear driver passenger) is bone dry. At first I thought it was just someone spilling some water that seeped through the foam and collected on the frame so I removed the entire bench to air dry and monitor the area after drying. The day after was a full Florida day with outside temperatures >100F and only moving the car once, at the end of the day water still pooled in that same exact spot when I went to re-install the bench.
I did a search to see if anyone else was having a similar problem and it seems only the front seats were having water problems with no mention of rear seats and the solution was to unclog an evaporator line. Does anyone have any suggestions on what could be causing the water puddle?
