Do you have a wiring diagram for the engine donor and your matrix?
I'd recommend the three month or one year options.Spend $20 bucks and get the diagrams for both.
Sounds like you need to add those pins to the plug(s). Its not something I had to do for my swap but its easy enough. The little metal pins inside the plastic plug can be taken out or put in as needed.No I can't really find a good diagram for the xr...im using the original harness from the 1zz....it says to add a wire from c6 and c7 and c21 and that c7 is blank but on my harness c6 is blank so there is conflicting info...I hate wiring....im just hoping someone here has answers for me
Is there anyway I could get those diagrams as well?? Im done with the swap but car won't start. Please these would be a great help!! Thanks in advance.PM me. I have diagrams.
Hey. Sorry to be a pain. But do you have the diagram for the 04 matrix xrs ecu pinout. I'm at a standstill. Just need to know where a couple things go. Thank you so much.PM me. I have diagrams.
You will need to get a 03 matrix xrs ecu. The 04 matrix xrs ecu has no mods to it. Basically a brick. Don’t know why, but Toyota made it on just the 04.Hey. Sorry to be a pain. But do you have the diagram for the 04 matrix xrs ecu pinout. I'm at a standstill. Just need to know where a couple things go. Thank you so much.
Idk what you mean! Either way what I have is the 04 xrs ecu. I just need to know what pins to hook up the clutch so when I push the clutch in it will start. Also where to pin the lift solenoid and oil sensor for that side of motor. I have 1zz harness so I will just want to run wires myself. If you can help with that for now. I'm getting a 03 xrs ecu later. Ijust need car to go up and down the road for now. Thanks in advanceYou will need to get a 03 matrix xrs ecu. The 04 matrix xrs ecu has no mods to it. Basically a brick. Don’t know why, but Toyota made it on just the 04.
The slots that are blue are the wires you need to add from the 1zzharness to the 2zz ECUIdk what you mean! Either way what I have is the 04 xrs ecu. I just need to know what pins to hook up the clutch so when I push the clutch in it will start. Also where to pin the lift solenoid and oil sensor for that side of motor. I have 1zz harness so I will just want to run wires myself. If you can help with that for now. I'm getting a 03 xrs ecu later. Ijust need car to go up and down the road for now. Thanks in advance
So the only one I did was run the ignition switch (D9)plug to a switched power or else you won't have any check engine light and then you have to find a harness to cut and add the 3 wires for lift...and then it should run...I'm doing an 04 xr matrix and putting a 2zz also....the rest of the blue ones you don't have to do it just shows what is differentI don't understand. I'm not a dummy lol but, I only have the 3 wires. I see where to put them. But the auto trans?? Efi main relay?? Ignition switch?? What do I do with those 3 blue spots??
I just ran a small jumper wire from plug D9 to D1 because it is switched powerI don't understand. I'm not a dummy lol but, I only have the 3 wires. I see where to put them. But the auto trans?? Efi main relay?? Ignition switch?? What do I do with those 3 blue spots?? I have the 6 speed gearbox. Not auto trans.
I put the d9 pin at D1...I just cut out the ECU pin for cruise control pinned it into d9 then jumped it to D1 for switched powerWhere did you move the d9 pin?? And since I have you here. Where do I run the wires from clutch switch to have the car start. Or can I just bypass that?? Of course I wouldn't have the safety of not being able to start it with out clutch in but im the only driver so no worries there if I can bypass it
