Hello All,
It's not that I don't understand where these are located and how, in theory, one changes them, but it looks to be a grand PITA to get at them (as opposed to the low and high beam headlamps) on this car.
I have a turn signal bulb on the left front that works as a turn signal but does not illuminate as a side-marker lamp when the headlights are on like the one on the right side does. I imagine this means a broken filament. I am anticipating replacing this with an LED equivalent barring some persuasive argument as to why one cannot or should not do this (and I have done so on other cars).
To even get near the thing on the driver's side, it looks like I'd have to pull the battery, and even then it wouldn't be a particularly easy reach.
Is there some trick (obvious or not) that would make the changing of the front turn signal lamps far easier than it appears it will be?
