this is in response to hardtopte,,,,,just to clarify...i pulled harmonic balancer ...keyway is at12oclock on compression stroke, so for conversation sake, lets assume crank timing is correct, i also have the valve cover off and both cams are off a tooth....what is the procedure for setting cam timing without pulling chain cover off? i am guessing i have to back off on the chain tensioner and individually put a wrench on each camshaft and try to rotate to slip a link?
i've injured my back and leg so removing the chain cover will be a difficult job for me, not to mention a ton more work, not to mention its cold as heck here..have a heater in garage.....but no insulation so doesn't help much....cold concrete, cold tools, cold car....quicker i can fix this the better
searched for vids on just cam timing or replacing cams on this engine with no luck...really need my camry back on road...my one ton truck is killing my back on connecticut roads, not to mention my wallet
