I've searched the forum to see if anyone is having similar issues but can't find anything. Here's my problem.
A few weeks back I got an engine code of P0306 which is a cylinder #6 misfire. I changed the plugs since it was due and the code cleared but a couple weeks later I noticed that my engine coolant was low.
After some additional troubleshooting I have determined that the left bank head gasket is bad and needs to be replaced. What's happening is that when the engine is running it is over-pressurizing the cooling system and causing the coolant to be pushed out of the system via the radiator cap. I also see bubbles rising from the coolant recovery tank from the increased pressure in the system.
The reason that I got the P0306 code is that coolant is leaking into the #6 cylinder and causing the misfire. Also, when the engine is running, combustion gases are bleeding through to the cooling system.
I will say that this is all based on my findings so far but I will be bringing my Taco to the dealer this Saturday to have it checked out.
I would ask that anyone who has had this problem respond to this thread as by searching the Internet I have found several more complaints of this on Tacomas, FJ's and 4-Runners and more of us may have this problem as our trucks rack up more miles.
Mine has just over 94K on it now and is extremely well maintained so this is very premature for a Toyota.
I'll keep you informed of my progress as I do believe that Toyota should take care of this even though my truck is out of warranty. Needless to say I am very bummed out.
