1 - 6 of 6 Posts
G
Discussion Starter · #2 ·
<[email protected]> wrote in message
news:[email protected]
> Hi,
> Try to do tire rotation on 2005 Corolla CE but the rear rim are still
> 'locked' to the hub after unscrewing 6 lug nuts.
> Please advise.
I use a rubber mallet in that situation. It also works well for removing
the rear drums.
G
Discussion Starter · #3 ·
"Truckdude" <[email protected]> wrote in message
>> Hi,
>> Please advise.
> the rear drums.
Put the lug nuts back on hand tight and drive once around the block. Repeat
as necessary.
G
Discussion Starter · #5 ·
Must be a 4Rnr chassis on a Corolla body for 6 lug nuts (maybe counting the
mechanic). Loosen the lugnus few turns and drive the car few hundred feet
and the wheels whould break loose from hubs. Use anti-seize when re
installing then --- or grease.
"Philip" <[email protected]> wrote in message
>> Hi,
>> Please advise.
>> Best regards,
>> [email protected]
>> [email protected]
>> http://www.bankarea.com
> There are only FIVE lug nuts on each rim.
> Do you operate the car where salt is used to de-ice the roads?
1 - 6 of 6 Posts
