1 - 5 of 5 Posts
· RLD AU FAN
'06 Avalon XLS
I've read the multiple posts about devices that can be used to add an aux input (i.e., Ipod) using the wiring harness that plugs into the back of the head unit. I previously installed a factory XM radio using such a harness. My question is, can these devices be installed at the wiring going into the cassette deck? The connector that plugs into the cassette deck is a 12 pin that looks identical to the connector that goes into the head unit. It would seem that there would be a way to use the cassette wiring to add the auxilliary input, but I've not seen it. I don't care if this make the cassette deck inoperable. Any one try anything like this?
One option i looked at was to buy an in-line FM modulator. So, basically you tune the radio into the station the FM modulator is broadcasting on. This is much better than a wireless broadcaster because it is basically injecting the signal directly into the radio's antenna. Just do a google search on auto fm modulator and you'll see what I'm describing.
If you do this you will be limiting your frequency response to <15khz
I too would like some info on using the cassette input instead of the sat input
1 - 5 of 5 Posts
