Car: Corolla 2006 LE. After putting in a new battery, I searched but was unable to find an anchoring "hole" for the hook end of the L-shaped rod that is used for holding down the hold-down clamp on top of the battery. There was no such hole on the battery tray like it was normally located on the edge of the battery tray in other models of car. I tried to insert the L-shaped end under the battery tray but it would not stay and kept slipping out when I tried to tighten the nut on top of the hold-down bracket. I would appreciate it if someone can tell, with a photo if possible, where the anchoring hole is and if there is not one then how to secure the battery in place with the hold-down bracket. The other end of the bracket is set to be tied down with a screwed-in bolt onto the frame in the front portion of the car. Thanks.
