1 - 2 of 2 Posts
I just picked up a 07 with a 6 speed manual. 1st gear is so bad I decided to bypass it like the old creeper gear and come out in 2nd gear. Works like a charm but does anyone know if this is a problem or not?
If you're not good at it you may abuse the clutch a bit. Otherwise should be fine except if hauling a heavy load, you may want 1st back.
1 - 2 of 2 Posts
