1 - 20 of 20 Posts
G
I've decided I'd rather have a new '06 Camry from Japan instead
of a more stylish '07 Camry from Georgetown--just my personal
preference (I'm sure both cars are great machines).
Of course, the best of both worlds would be to buy the
re-styled '07 *AND* have it come from Japan. But I'm worried
when the '07s become available in March, none will be from Japan?
The Saint Louis dealer 100 miles away told me
they usually only get Japan cars at the end of the year.
What do you all think--any '07 J-cars comin' in March?
Thanks.
G
Discussion Starter · #2 ·
"Built_Well" <[email protected]> wrote in message
news:p[email protected]
> Thanks.
West coast dealers will have them.
G
Discussion Starter · #3 ·
One of Toyota's engineers had this to say about the new
6-speed automatic transmission that's available with
the six-cylinder (V6) '07 Camry:
"The old five-speed automatic transmission was much more
expensive than the new six-speed automatic. The new transmission
has 20 percent fewer parts and reduced weight. I don't know how much
less it costs to build, but from the start of development, engineering
was working to reduce parts and increase performance."
G
Discussion Starter · #4 ·
> "...from the start of development, engineering was working
Interesting that he didn't have anything to say about reliability.
G
Discussion Starter · #5 ·
'Available,' does that mean it will be optional or standard equipment?
mike hunt
news:[email protected]
G
Discussion Starter · #6 ·
"Mike Hunter" <[email protected]> wrote in message
> mike hunt
It looks like 4 cylinder Camrys get a five speed automatic and 6 cylinder
Camrys get a 6 speed automatic.
Ray O
G
Discussion Starter · #7 ·
(!) Sounds like people may want to pick up a 2006 with the now-proven
transmission before getting a 2007 with a cheap knock-down tranny.
The 07 looks more Frankenstein-ish of styles from other makes (such as
the G35 mix others posted) than innovative. But it's less bland to say
the least.
G
Discussion Starter · #8 ·
Fewer parts sounds like a good starting point to me. I'd take this risk, if
I were in the market for a V6 Camry (but I don't need that much power and I
like my fuel economy). I'd rather take a chance on this transmission than a
first-year transmission from Ford. I wonder how those CVTs are holding up?
Still, 6-speeds has got to be reaching the limit for marginal return; it
can't be very much more efficient or useful than a 5-speed. I wonder if it
shifts faster? That might make a difference in performance.
> the least.
I've only seen photos but I thought it looked good. I'm not a big fan of
the looks of the current Camry. This one looks, somehow, similar but
better.
G
Discussion Starter · #9 ·
"DH" <[email protected]> wrote in message
> if
> I
> a
> up?
> it
I have not seen any technical reports on the 6-speed transmission but my
guess is that there is another planetary gear set. The number of speeds
does not have any bearing on how "fast" a transmission shifts. A fast shift
will be more efficient although the shifts will feel harsh.
As a general rule, more gear ratios will mean better fuel economy and/or
performance. The limiting factor in the number of gear ratios is the extra
weight, cost, and complexity that come with more gear ratios.
I've hear rumors that the next generation Lexus LS will have an eight speed
transmission...
Ray O
G
Discussion Starter · #10 ·
Like the Fusion, seems the smaller engine could make better use of the extra
gear to help it stay up on the torque curve. ;)
mike hunt
"Ray O" <[email protected]> wrote in message
>> mike hunt
> Ray O
G
Discussion Starter · #11 ·
> extra gear to help it stay up on the torque curve. ;)
> mike hunt
I'm with you there! I see the same "reverse" thinking on many different
makes - more gears mated with more horsepower and torque instead of with
less horsepower and torque, where the extra speeds would improve
performance.
Ray O
G
Discussion Starter · #12 ·
>> mike hunt
So, what would be the 6th speed? Ultra overdrive?
> Ray O
G
Discussion Starter · #13 ·
I was looking at a Mazda 5 and the epa figures were almost identical for the
manual and automatic. I think they were 1 mpg different City and Highway.
> if
> I
> a
> up?
> it
>> the least.
> better.
G
Discussion Starter · #14 ·
8 speed AT? Either that metal has got to be getting stronger or the AT has
got to be getting bigger.
>> if
>> I
>> than a
>> up?
>> it
> shift will be more efficient although the shifts will feel harsh.
> extra weight, cost, and complexity that come with more gear ratios.
> speed transmission...
> Ray O
G
Discussion Starter · #15 ·
> if
> I
> a
> up?
My Father has a CVT in a Freestyle. It has been flawless. Very good
transmission (sourced from ZF in Europe). Interestingly, the Five Hundred
and Fusion both use Aisin Warner Automatic Transmissons (if you don't get
the CVT i the Five Hundred). Since this company is primarly owned by Toyota
and is a prime Toyota supplier, don't you supppose the awesome, wonderfiul
supper great Toyota 6 speed automatic is the same as or at least very
similar to the piece of crap 6 speed tranmission sold in the Fusion? Oh
what a feeling. Moving forward....;
Ed
G
Discussion Starter · #16 ·
"Sharx35" <[email protected]> wrote in message
> news:[email protected]s.com...
>>> mike hunt
>> Ray O
Additional gear ratios are generally added between existing ratios rather
than at the high end.
Ray O
G
Discussion Starter · #17 ·
"Art" <[email protected]> wrote in message
An extra planetary gear set would probably add about 2 or 3 inches to the
transmission's overall length at the most.
Ray O
G
Discussion Starter · #18 ·
Many of the Toyota auto trannnys are made in Durham NC and Virginia.
"C. E. White" <[email protected]> wrote in message
>> if
>> I
>> than a
>> up?
> Toyota and is a prime Toyota supplier, don't you supppose the awesome,
> wonderfiul supper great Toyota 6 speed automatic is the same as or at
> least very similar to the piece of crap 6 speed tranmission sold in the
> Fusion? Oh what a feeling. Moving forward....;
> Ed
G
Discussion Starter · #19 ·
On Mon, 16 Jan 2006 22:41:00 -0600, "Ray O"
<[email protected]> wrote:
>"Art" <beguna[email protected]> wrote in message
Maybe not - it might just need an extra clutch pack or two, and a
smarter computer to run them all. You can get several different gear
ratios out of a planetary (both speed increase and reduction)
depending on which of the three elements is the drive, driven, and
stopped/locked part - but AIUI they usually only use two.
They might have come up with a way to shift a few of the existing
planetary sets into additional useful ratios.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
G
Discussion Starter · #20 ·
In article <[email protected]>,
Reduced parts count is normally a big factor in improving reliability, so
I would expect the new tranny to be more reliable.
Merritt
1 - 20 of 20 Posts
