1 - 1 of 1 Posts
2009 Corolla
159K miles, the only major repair was the serpentine belt split and took out the water pump at 157K. Since the repairs, there is a tiny chirp noise on startup and noticeable clicking noise when the engine is under load (drive or reverse with brake applied). In park at idle if the noise is there it is not very loud. This morning with a cold soaked engine there was no noticeable clicking below 900 rpm. In drive with brakes applied, the idle at ~850 rpm, good amount of noise. Turn on the A/C, idle increases to ~1000 RPM noise goes away.
What is a good site to upload videos to show everyone?
Other than a P0354 intermittent code that seems to be solved by spark plug and ignition coil replacement no issues, excellent car.
1 - 1 of 1 Posts
