Hey, my 2009 Camry was driving normally when it threw out vehicle stability control, traction control, and check engine lights on the dash. A code reader said DVVT System Retard Malfunction, Brake Boost Sensor Circuit Range/Performance, and Low Battery Positive Voltage or Abnormally High Battery Positive Voltage. Has anyone seen this combination of codes before? Based on how it was driving fine I'd like to believe I don't actually have to replace the VVT assembly.
Thanks!
11/5 Edit: Codes went away after driving then getting gas. Everything is driving fine so I'm assuming it was a stupid sensor triggering other warnings. Thanks for the help!
Thanks!
