Hi. I decide to go with a minor suspension lift on my 1993 2wd x-cab using the same parts that Ajones1165 used (SDORI 1.5" BJ Spacers, Procomp add-a-leaf, and longer Bilstein shocks for the rear). The goal is to be able to install at least 235/75R15 Geolanders.
I installed all the parts today. The rear of my truck now sits 2" higher, but the front gained only a half inch in height. Why after installing 1.5" ball joint spacers did the front only go up a half inch? I drove the truck around to see how it would settle but that didn't helped. I have not touched the torsion bars yet. I figured I'd crank them a little to try to get the front from 1.5" to 2" to match the rear, but isn't raising the front 1.5" by cranking the torsion bars too much? What am I missing?
Thanks!
Thanks!
