1000 RPM Increase While Driving
1045 Views 3 Replies 3 Participants Last post by  labdad
During cold weather the 3.0 engine in my 1992 P/U will increase 1000 rpm while driving, similar to a downshift but that's not what it's doing. I can turn the ignition off/on and that usually clears it, only to keep repeating. It's a real pain when 40 below. Any suggestions? :sosad:
1 - 4 of 4 Posts
Is this an automatic tranny?
Automatic transmissions will not shift into overdrive below a certain engine temperature. And if you are driving and it is in overdrive and the temperature drops below that point then it will drop out of overdrive. So if your thermostat is not functioning correctly and it is really cold out side then your engine could hover around this temp and drop in and out of overdrive.
There can also be a blockage in the coolant pipe or hose that circulates coolant through the sensor block that will prevent the sensor from reading the correct temperature.
Also there is a year or two of that model(don't recall exatly what year) that had a problem with a ground splice in the wiring harness that would increase the resistance on the sensor circuit and cause the ECM to read the temp as lower than what it actually is resulting in much the same problem.
Hopefully this info will get you going in the right direction
Thanks
Thanks for the tips. Yes, it is an automatic and just may be dropping out of OD.
1 - 4 of 4 Posts
