Status
Not open for further replies.
1 - 2 of 2 Posts
Vivir el momento
Corolla
The following is a list of all the DIYs available for 10th gen Corollas and 2nd Gen Matrix.
If you come up with a new one or find one that's missing, please PM me and I will add it to the list.
General:
10th Gen Corolla General Info Thread (Everything you need to know!)
https://www.toyotanation.com/forum/149-corolla-10th-gen-2nd-gen-matrix-2009-2013/365333-10thgen-everything-you-need-know.html
Official Photoshop Thread
https://www.toyotanation.com/forum/showthread.php?t=385387
Comprehensive TSB Listing for 2ZRFE
https://www.toyotanation.com/forum/showthread.php?t=345834
Official Aftermarket Parts Thread
https://www.toyotanation.com/forum/showthread.php?t=331760
2009 Corolla - info sites from Toyota
https://www.toyotanation.com/forum/showthread.php?t=234129
Light bulb sizes
https://www.toyotanation.com/forum/showthread.php?t=353835
Printable Maintenance Schedule
https://www.toyotanation.com/forum/showthread.php?t=320485
Brakes, Steering & Suspension
DIY: Brake Guide
https://www.toyotanation.com/forum/showthread.php?t=367175
DIY S Rear Disc Brake Swap
https://www.toyotanation.com/forum/324-corolla-10th-gen-2nd-gen-matrix-suspension-brakes-wheel-forum/390125-diy-10th-gen-corolla-s-rear-disc-brake-swap.html
DIY: Disabling VSC (for Track purposes only)
https://www.toyotanation.com/forum/showthread.php?t=302580
DIY: Front Strut Brace
https://www.toyotanation.com/forum/showthread.php?p=3248923
DIY: Rear Strut Bar (with pics)
https://www.toyotanation.com/forum/showthread.php?t=345509
DIY: TRD Lowering Springs Installation
http://trdsparks.com/install/PTR40-02080inst.pdf
How To Install/Replace Front Strut Bar
https://www.toyotanation.com/forum/showthread.php?t=371145
How To Replace Front Strut Coil Springs
https://www.toyotanation.com/forum/showthread.php?t=371094
How To Replace Rear Shock Coil Springs
https://www.toyotanation.com/forum/showthread.php?t=370848
How To Replace Rear Sway Bar
https://www.toyotanation.com/forum/showthread.php?t=370755
List of Tools Required to Install Lowering Springs
https://www.toyotanation.com/forum/showthread.php?t=308046
Lowering springs FAQ
https://www.toyotanation.com/forum/showthread.php?t=333694
Engine
DIY: Maintenance - Oil Filter and other parts and their “Part #” reference
https://www.toyotanation.com/forum/showthread.php?t=283566
DIY: Serpentine Accessory Belt Replacement
https://www.toyotanation.com/forum/323-10th-gen-corolla-2nd-gen-matrix-engine-transmission-forum/964969-diy-serpentine-accessory-belt-replacement-guide-2zr-fe-1-8l-engine.html#post8397921
DIY: Oil Catch Can
https://www.toyotanation.com/forum/323-10th-gen-engine-transmission-forum/519233-diy-oil-catch-can.html#post4898777
DIY: Block heater install
https://www.toyotanation.com/forum/showthread.php?t=369680
Pivot 3 Throttle Controller Install
https://www.toyotanation.com/forum/showthread.php?t=358389
DIY: Turn your stock intake into CAI/partial ram air
https://www.toyotanation.com/forum/showthread.php?t=334733
DIY: Greddy Emanage/Ultimate Wiring for 2ZR-FE
https://www.toyotanation.com/forum/showthread.php?t=450953
Exterior
Front bumper removal guide
https://www.toyotanation.com/forum/showthread.php?t=326016
Rear bumper removal write up
https://www.toyotanation.com/forum/showthread.php?t=325696
DIY: VIP Puddle Lighting (LED Strip Method | 2 Side Driver/Passenger | Unlock/Open)
https://www.toyotanation.com/forum/showthread.php?t=433238
Backup sensor installed on 2009 Corolla S w/pics
https://www.toyotanation.com/forum/showthread.php?t=313354
DIY: Additional Brake Lights
https://www.toyotanation.com/forum/showthread.php?t=304168
DIY: Clear Bra Door Cup Protection
https://www.toyotanation.com/forum/showthread.php?t=371070
DIY: Disable DRL / Autolights and/or Independent Fog Light Mod w/ Pics
https://www.toyotanation.com/forum/showthread.php?t=309869
DIY: Front Plate Relocation (lower grill)
https://www.toyotanation.com/forum/showthread.php?p=3463508
DIY: Gas Shock Hood Damper
https://www.toyotanation.com/forum/showthread.php?t=359965
DIY: Hella Horn Install
https://www.toyotanation.com/forum/showthread.php?t=375671
DIY: Hella Horn Brackets
https://www.toyotanation.com/forum/showthread.php?t=392515
DIY: Custom Dual Horn Install Cable (NO SPLICE!)
https://www.toyotanation.com/forum/showthread.php?t=399670
DIY: How to customize front emblem
https://www.toyotanation.com/forum/showthread.php?t=362448
DIY: LED Headlight Strip Install
https://www.toyotanation.com/forum/showthread.php?t=363892
DIY: LED Strip over leadlights
https://www.toyotanation.com/forum/showthread.php?p=2913228
DIY: Stock to LED Turn Signal Swap
https://www.toyotanation.com/forum/showthread.php?t=371389
DIY: Installing Fog Lights
https://www.toyotanation.com/forum/showthread.php?t=349808
Light setup pictures thread
https://www.toyotanation.com/forum/showthread.php?t=334475
DIY: Front Bumper/Head Light Removal and Projector Retrofitting [HEAVY PICS]
https://www.toyotanation.com/forum/showthread.php?t=399665
DIY: Alternate License Plate Lights
https://www.toyotanation.com/forum/showthread.php?t=395917
https://www.toyotanation.com/forum/149-corolla-10th-gen-2nd-gen-matrix-2009-2013/377955-how-enable-disable-auto-door-lock-corolla-manual-automatic.html
DIY: Roof Vinyl
https://www.toyotanation.com/forum/showthread.php?t=389210
Interior
How to Enable/Disable Auto Door Lock on Corolla (Manual or Automatic)
DIY: 1st Gen tC console arm rest
https://www.toyotanation.com/forum/showthread.php?t=382459
DIY: 2011 Corolla Antenna Plug Mod
https://www.toyotanation.com/forum/showthread.php?t=410292
DIY: Dome Light Removal
https://www.toyotanation.com/forum/showthread.php?t=364011
DIY: Radio Removal
https://www.toyotanation.com/forum/showthread.php?t=251982
Headliner Disassembly Video DIY Tutorial
https://www.toyotanation.com/forum/showthread.php?t=278356
My pedal "fix" on my XRS
https://www.toyotanation.com/forum/showthread.php?t=335750
DIY: Steering wheel control add-on for CE/LE
https://www.toyotanation.com/forum/showthread.php?p=3547298#post3547298
DIY: Fixed to variable intermittence wipers, switch swap
https://www.toyotanation.com/forum/showthread.php?t=1492258
Rosen Install W/ Special features working: Backup Camera+BrakeBypass
https://www.toyotanation.com/forum/showthread.php?t=395203
DIY: Amp power through firewall and connect sub to stock stereo
https://www.toyotanation.com/forum/showthread.php?t=1494450
Disabling auto door locking mechanisms
https://www.toyotanation.com/forum/showthread.php?p=2930710
DIY: Door Inserts!!!
https://www.toyotanation.com/forum/showthread.php?t=384392
DIY: LED OEM Doorsills connected to door switch circuit
https://www.toyotanation.com/forum/showthread.php?t=421260
DIY: Footwell and Rear Passenger Lights
https://www.toyotanation.com/forum/showthread.php?t=312747
DIY: Footwell LED's using the dome light as a switch
https://www.toyotanation.com/forum/showthread.php?t=314744
DIY: Illuminated Footwells & Cupholders with Switch!
https://www.toyotanation.com/forum/showthread.php?p=3663827
DIY: How To Make Your Own Cabin Filter
https://www.toyotanation.com/forum/showthread.php?t=380408
DIY: How to replace stock speakers
https://www.toyotanation.com/forum/showthread.php?t=280465
DIY: Hvac LED swap
https://www.toyotanation.com/forum/showthread.php?t=319869
DIY: Shift boot install
https://www.toyotanation.com/forum/showthread.php?t=351915
DIY: Under-Dash Lighting
https://www.toyotanation.com/forum/showthread.php?t=310574
How to Make Your Own Rear Speaker Adapters
https://www.toyotanation.com/forum/showthread.php?t=331744
OEM XM Radio Install Video
https://www.toyotanation.com/forum/showthread.php?t=375822
Rear Deck Removal/Rear Speaker Replacement DIY
https://www.toyotanation.com/forum/showthread.php?t=333010
DIY: Sirius Install
https://www.toyotanation.com/forum/showthread.php?t=305721
DIY: Corolla Flip Key
https://www.toyotanation.com/forum/showthread.php?t=402127
DIY: Flip Key Remote Swap
https://www.toyotanation.com/forum/showthread.php?t=405188l
DIY: Fiber Optic Headliner
https://www.toyotanation.com/forum/149-corolla-10th-gen-2nd-gen-matrix-general-discussion-forum/1609842-fiber-optic-headliner.html#post13653698
Wheels & Tires
Official Wheel Thread
https://www.toyotanation.com/forum/149-corolla-10th-gen-2nd-gen-matrix-2009-2013/237610-official-10th-gen-corolla-wheel-thread-post-all-wheel-related-questions-here.html
Winter Tire and Tire Pressure Thread
https://www.toyotanation.com/forum/showthread.php?t=299314
Useful Threads!​
List of DIYs! (Do it yourself)
https://www.toyotanation.com/forum/showthread.php?t=310590
What did you do to your Corolla today?
https://www.toyotanation.com/forum/showthread.php?t=344057&page=141
10thGen Chat Thread
https://www.toyotanation.com/forum/showthread.php?t=361534&page=15
1.8L 2ZR-FE Aftermarket Parts List
https://www.toyotanation.com/forum/showthread.php?t=331762
2.4L XRS Aftermarket Parts List
https://www.toyotanation.com/forum/showthread.php?t=331753
HID FAQ MEGATHREAD! Post your questions HERE.
https://www.toyotanation.com/forum/showthread.php?t=344970
9012/9011 HIR Headlight Bulb Upgrade
https://www.toyotanation.com/forum/showthread.php?t=330299
Lowering Spring: All your questions answered!
2009 Corolla Rims Thread!
https://www.toyotanation.com/forum/showthread.php?t=237610&page=71
DIY Home Depot Lip Splitter
https://www.toyotanation.com/forum/showthread.php?t=361697
Red Out Tails and Tint Foglights
https://www.toyotanation.com/forum/showthread.php?t=362427
How much did you pay for your Corolla OTD?
https://www.toyotanation.com/forum/showthread.php?t=311403
Shift Knob thread: Show off your knobs
https://www.toyotanation.com/forum/showthread.php?t=337639&highlight=shift+knob
Borla vs. MagnaFlow Exhausts
https://www.toyotanation.com/forum/showthread.php?t=361270
MagnaFlow Exhaust
https://www.toyotanation.com/forum/showthread.php?t=321708
Borla Exhaust
https://www.toyotanation.com/forum/showthread.php?t=342277&highlight=borla
Injen Exhaust
https://www.toyotanation.com/forum/showthread.php?t=361390
WeatherTech Floor Liners
https://www.toyotanation.com/forum/showthread.php?t=341592
Turbo 2.4L Research/Discussion
https://www.toyotanation.com/forum/showthread.php?t=359364
If you think any other threads should be added let me know!
If you find any other relevant information that should be on this thread, please let me know!
1 - 2 of 2 Posts
Status
