1 - 20 of 51 Posts
10th Generation Corolla
E140/E150
General Info
Production Years
Worldwide: 2006-Present
North America: 2007-2013
Japan: 2006-2012
International: 2006-2013
South Africa: 2007-Present
Platform
E140: MC Platform
E150: New MC Platform
Related/Badge Engineered Vehicles
Pontiac Vibe
Scion XB
Toyota Corolla Rumion​
North American Sedan Specs
Year / Models / Engine Code / Transmission:
2009-2010 / CE/L / 2ZR-FE / MT (5 Spd) & AT (4 Spd)
2009-2010 / LE / 2ZR-FE / AT Only (4 Spd)
2009-2010 / XLE / 2ZR-FE / AT Only (4 Spd)
2009-2010 / S / 2ZR-FE / MT (5 Spd) & AT (4 Spd)
2009-2010 / XRS / 2AZ-FE / MT (5 Spd) & AT (5 Spd)
2011-2013 / CE/L / 2ZR-FE / MT (5 Spd) & AT (4 Spd)
2011-2013 / LE / 2ZR-FE / AT Only (4 Spd)
2011-2013 / S / 2ZR-FE / MT (5 Spd) & AT (4 Spd)
2011-2012 / XRS / 2AZ-FE / MT (5 Spd) & AT (5 Spd)
CE(L)/LE/XLE on Left & S/XRS on Right
Models may Vary!
Mid-Generation Refresh
Corolla 1.8L Dual VVT-i
Trims: CE/L, LE, XLE, S
Chassis Code: ZRE142
Engine Code: 2ZR-FE
132 HP @ 6000 rpm
128 lb-ft. @ 4400 rpm
Transmissions:
-C59 5 Speed Manual (CE/L, S)
-U341E 4 Speed Auto (CE/L, LE, XLE, S)
Corolla 2.4L VVT-i
Trims: XRS
Chassis Code: AZE141
Engine Code: 2AZ-FE
158 HP @ 6000 rpm
162 lb-ft @ 4000 rpm
Transmissions:
-E351 5 Speed Manual (XRS)
-U250E 5 Speed Auto (XRS)
Weight and Capacities
Curb Weights kg(lbs.):
CE/L 5Spd MT - 1235 (2723)
CE/L 4Spd AT - 1245 (2745)
LE 4Spd AT - 1245 (2745)
XLE 4Spd AT - 1275 (2811)
S 5Spd MT- 1255 (2767)
S 4Spd AT - 1280 (2822)
XRS 5Spd MT - 1304 (2877)
XRS 5Spd AT - 1345 (2965)
Mid-Generation Refresh:
CE/L 5Spd MT - 1241 (2734)
CE/L 4Spd AT - 1255 (2767)
LE 4Spd AT - 1270 (2800)
S 4Spd AT - 1270 (2800)
Towing Capacity kg(lbs.): 680 (1500)
Fuel Tank liters(gal): 50 (13.2)
Fuel Economy (US MPG)(City/Highway):
CE/L 5Spd MT - 26/35
CE/L 4Spd AT - 27/35
LE 4Spd AT - 27/35
XLE 4Spd AT - 27/35
S 5Spd MT- 26/35
S 4Spd AT - 27/35
XRS 5Spd MT - 22/30
XRS 5Spd AT - 22/30
Color Codes and Colors:
040 Super White
1F7 Classic Silver Metallic
1G3 Magnetic Gray Metallic
209 Black Sand Pearl
4Q2 Desert Sand Mica
4T8 Sandy Beach Metallic
4R8 Hot Lava
3R3 Barcelona Red Metallic
779 Capri Sea Metallic
8U6 Tropical Sea Metallic
8T7 Blue Streak Metallic
8S6 Nautical Blue Metallic
9AH Black Currant
Wheel and Tire Specs!
Basic Specs
Bolt Pattern: 5x100mm
Thread Pitch: 12x1.5
Hub Diameter: 54.1mm
Factory Corolla CE/L Specs
Wheels: 15" Steel Wheels w/ Wheel Covers, 15x6.0
Offset: +33
Tires: P195/65R15
Factory Corolla LE Specs
Wheels: 15" Steel Wheels w/ Wheel Covers (Optional 16" Alloys), 15x6.0 (with Optional 16" wheels 16x6.5)
Offset: +33 (with Optional 16" Wheels +39)
Tires: P195/65R15 (with Optional 16" Wheels P205/55R16)
Factory Corolla XLE Specs
Wheels: 16" Steel Wheels w/ Wheel Covers (Optional 16" Alloys), 16x6.5
Offset: +39
Tires: P205/55R16 (with Optional 16" wheels P205/55R16)
Factory Corolla S Specs
Offset: +39
Factory Corolla XRS Specs
Wheels: 17" Alloy Wheels, 17x7.0
Offset: +39mm
Tires: P215/45R17
Bulb Sizes
Low Beam Bulb: 9006
High Beam Bulb: 9005
Front Turn Signal: 3457A
Front Sidemarker: 168
Fog/Driving Light: H11
Tail Light/Brake Light: 7443
Rear Sidemarker: 7443
Parking Light: 3457A
Rear Turn Signal: 3156
High Mount Stop Light: LED Assembly
License Plate Light: 168
Back Up Light: 921
Map light: 175
Dome light: DE3175
Trunk/Cargo Area: 168
Transmission Gear Indicator Light: 74
Model Year Changes
2009
-introduction year/first year of production for the 10th gen Corolla in the North American Market​
2010
2011
*Mid-Cycle Refresh*
- Xrs is still listed as available in Auto and Manual using the 2AZ-FE, kept the same wheels.
- The acoustic type windshield glass has been discontinued.
- The accessory socket in the rear console box has been discontinued on all models.
- The rear spoiler is now also available as optional equipment on TMMC production LE grade models for U.S.A.-destination.
- The console side box has been discontinued.
- The shape of the rear console box has been changed to increase the capacity.
- Looks like leather is no longer available on any models any longer.
- 1.8L models get a newer, better (?) A/C compressor type.
- Optitron gauges are discontinued on all models, from the pics it looks like perhaps they still have similar needles? Highly unfavourable though.
- Cruise "SET" light added to gauge cluster.
- Factory navigation is no longer available.
- The S/XRS badge on the front grille is discontinued.​
2012
2013
International Altis Sedan Specs​
Engine Variants Available
Petrol:
1.3L 2NZ-FE
1.4L 4ZZ-FE
1.5L 1NZ-FE
1.6L 3ZZ-FE
1.6L 1ZR-FE
1.8L 1ZZ-FE
1.8L 2ZR-FE
2.0L 3ZR-FE
Diesel:
1.4L 1ND-TV
2.0L 1CD-FTV
Transmission Variants Available
Automatic:
4 Speed Automatic
5 Speed Automatic
7 Speed Super CVT-i
Manual:
5 Speed Manual
6 Speed Manual
JDM Axio Sedan Specs
Petrol:
1.5L 1NZ-FE
1.5L 1NZ-FTE (Turbo)
1.8L 2ZR-FE
Automatic:
7 Speed Super CVT-i
Manual:
5 Speed Manual
Discussion Starter #2 (Edited)
North American Hatchback Specs
2009-2010 / Base / 2ZR-FE / MT (5 Spd) & AT (4 Spd)
2009-2010 / XR / 2AZ-FE / MT (5 Spd) & AT (5 Spd)
2009-2010 / S / 2AZ-FE / MT (5 Spd) & AT (5 Spd)
2009-2010 / AWD / 2AZ-FE / AT Only (4 Spd)
2011-2014 / Base / 2ZR-FE / MT (5 Spd) & AT (4 Spd)
2011-2013 / S / 2AZ-FE / MT (5 Spd) & AT (5 Spd)
2011-2013 / S-AWD / 2AZ-FE / AT Only (4 Spd)
2011-2013 / AWD / 2AZ-FE / AT Only (4 Spd)
2011-2013 / XRS / 2AZ-FE / MT (5 Spd) & AT (5 Spd)
Base/XR/AWD on Left & S/S-AWD/XRS on Right
Models may Vary!
Matrix 1.8L Dual VVT-i
Trims: Base
Engine Code: 2ZR-FE
132 HP @ 6000 rpm
Transmissions:
-C59 5 Speed Manual (Base)
-U341E 4 Speed Auto (Base)
Matrix 2.4L VVT-i
Trims: XR, S, AWD, S-AWD, XRS
Chassis Code:
XR, S: AZE141
AWD, S-AWD: AZE144
XRS: AZE146
Engine Code: 2AZ-FE
158 HP @ 6000 rpm
Transmissions:
-E351 5 Speed Manual (XR, S, XRS)
-U250E 5 Speed Auto (XR, S, XRS)
-U140F 4 Speed Auto (AWD, S-AWD)
Base 5Spd MT - 1300 (2865)
Base 4Spd AT - 1345 (2965)
XR 5Spd MT - 1391 (3066)
XR 5Spd AT - 1426 (3144)
S 5Spd MT- 1391 (3066)
S 5Spd AT - 1426 (3144)
AWD 4Spd AT - 1524 (3360)
XRS 5Spd MT - 1424 (3140)
XRS 5Spd AT - 1461 (3220)
Base 5Spd MT - 1285 (2833)
Base 4Spd AT - 1305 (2877)
S 5Spd MT - 1350 (2976)
S 5Spd AT- 1385 (3053)
S-AWD 4Spd AT - 1485 (3274)
AWD 4Spd AT - 1480 (3263)
XRS 5Spd MT - 1395 (3075)
XRS 5Spd AT - 1430 (3153)
Base 5Spd MT - 26/32
Base 4Spd AT - 25/32
XR 5Spd MT - 27/35
XR 5Spd AT - 27/35
S 5Spd MT- 21/28
S 5Spd AT - 21/29
AWD 4Spd AT - 20/26
S-AWD 4Spd AT - 20/26
XRS 5Spd MT - 21/26
XRS 5Spd AT - 21/29
040 Super White
4T6 Sundance Metallic
3L5 Radiant Red
6V4 Spruce Mica
Basic Specs
Bolt Pattern:
Matrix 1.8L 5x100mm
Matrix 2.4L 5x114.3mm
Hub Diameter:
Matrix 1.8L 54.1mm
Matrix 2.4L 60.1mm
Factory Matrix Base Specs
Offset: +45 (with Optional 16" Alloys +39)
Tires: P205/55R16
Factory Matrix XR Specs
Wheels: 16" Steel Wheels w/ Wheel Covers (Optional 17" Alloys), 16x6.5 (with Optional 17" wheels 17x7.0)
Offset: +45 (with Optional 17" Wheels +39)
Tires: P205/55R16 (with Optional 17" Wheels P215/45R17)
Factory Matrix S Specs
Wheels: 16" Steel Wheels w/ Wheel Covers (Optional 16" Alloys & 17" Alloys), 16x6.5 (with Optional 17" Alloys 17x7.0)
Offset: +45 (with Optional 16" Alloys & 17" Alloys +39)
Tires: P205/55R16 (with Optional 17" wheels P215/45R17)
Factory Matrix AWD/S-AWD Specs
Wheels: 16" Steel Wheels w/ Wheel Covers (Optional 17" Alloys), 16x6.5 (with Optional 17" Alloys 17x7.0)
Offset: +45 (with Optional 17" Alloys +39)
Tires: P205/55R16 (with Optional 17" Alloys P215/45R17)
Factory Matrix XRS Specs
Wheels: 18" Alloy Wheels, 18x7.0
Offset: +39mm
Tires: P215/45R18
Bulb Sizes
Low Beam Bulb: 9006
Front Sidemarker: 3457A
Rear Turn Signal: 7440
Back Up Light: 921
Map light: 175
Dome light: DE3175
Trunk/Cargo Area: DE3175
Model Year Changes
2009
-introduction year/first year of production for the 2nd gen Matrix in the North American Market​
2010
2011
*Mid-Cycle Refresh*
2012
2013
2014
International Hatchback Specs
Petrol:
1.33L 1NR-FE
1.4L 4ZZ-FE
1.6L 1ZR-FE
1.6L 1ZR-FAE
1.8L 2ZR-FE
1.8L 2ZR-FAE
2.4L 2AZ-FE
3.5L 2GR-FE
Diesel:
1.4L 1ND-TV
2.0L 1AD-FTV
2.2L 2AD-FHV
Automatic:
4 Speed Automatic
5 Speed Automatic
7 Speed Super CVT-i
Manual:
5 Speed Manual
6 Speed Manual
JDM Fielder Wagon Specs
Petrol:
1.5L 1NZ-FE
1.8L 2ZR-FE
Automatic:
7 Speed Super CVT-i
Manual:
5 Speed Manual
Good job!
But regarding k-sport and H-tech dropping evidence, the tires used were both 235/45/R17 instead of the 215/45/R17, which maintain overall tire-wheel diameter. Here the difference is 20x45%=9mm. So the wheel gap if using 215/45/R17 should be about 2x9mm=18mm larger when dropped on those two brands of springs. Please correct me if I'm wrong.
09 Corolla S
Good job!
But regarding k-sport and H-tech dropping evidence, the tires used were both 235/45/R17 instead of the 215/45/R17, which maintain overall tire-wheel diameter. Here the difference is 20x45%=9mm. So the wheel gap if using 215/45/R17 should be about 9mm larger when dropped on those two brands of springs. Please correct me if I'm wrong.
i think i have around the same gap as clintj. 205/55/16
Discussion Starter #10
Thanks guys, Will be hopefully updating this periodically when I dig up for more info to help out members searching for long periods of times.
If you guys find anything that should be added, go ahead and post it and I'll update it ASAP.
The Corolla That Could
09 Corolla S
Good job!
Only half of the 18mm (so 9mm) would make a difference on fender gap. the other 9mm would affect the height of the car off the ground.
Diehard Rams Fan
Good job!
I will say though that the stock speedo reads fast if you check it with a GPS. My 225/45R17 tires are more accurate than my 215/45R17 tires are & I bet the 235/45R17 tires are almost exactly perfect for the speedometer. :D
I just ordered some hub centric spacers recently and this information might help for the people trying to figure out the hub centric ring diameter too..
hub diameter =54.1mm
1 - 20 of 51 Posts
