This thread contains various DIY's and important information for the 11th Gen Corolla. If you want me to add anything else that I may have missed, just tell me what it is by replying in this thread and I'll add it. I'll continue to update this thread as more DIY's are made.
DISCLAIMER: Certain links in this thread are not created by me and may be from a different forum or site. I do not take any credit for their work as this is just a compiled list of all DIY's related to the 11th gen Corolla.
Engine & Drivetrain Maintenance & Repair:
How to Change your Oil and Oil Filter
(http://www.paulstravelpictures.com/...lla-2ZR-FE-Engine-Oil-Change-Guide/index.html)
How to Change the Engine Air Filter
(http://www.paulstravelpictures.com/...ngine-Air-Filter-Replacement-Guide/index.html)
How to Change Manual Transmission Fluid
(https://www.toyotanation.com/forum/...30-changing-gear-oil-manual-transmission.html)
How to Reset the Maintenance Light
How to Change your Spark Plugs
(http://www.paulstravelpictures.com/...gine-Spark-Plugs-Replacement-Guide/index.html)
How to Change the Serpentine Accessory Belt
(http://www.paulstravelpictures.com/...-Serpentine-Belt-Replacement-Guide/index.html)
How to Change Electrical Fuses
(http://www.paulstravelpictures.com/...Electrical-Fuses-Replacement-Guide/index.html)
How to Replace Car Battery
(http://www.paulstravelpictures.com/...tomotive-Battery-Replacement-Guide/index.html)
How to Clean the Throttle Body
Engine Modifications:
How to Install the Injen Intake
(https://www.toyotanation.com/forum/377-11th-generation-2014/730362-injen-intake-installed.html)
*How To Install the Weapon-R Header
(https://www.toyotanation.com/forum/...rolla-2zr-fe-engine-aircmry.html#post11708001)
*How to Install an Oil Catch Can
(https://www.toyotanation.com/forum/...rum/519233-diy-oil-catch-can.html#post4898777)
How to Convert 2ZR-FE from Cartridge Oil Filter (09-15') to Spin-On Oil Filter (16'+)
(http://www.armstrongfamilyblog.com/armstrong-racing/the-2016-toyota-2zr-engine-oil-filter-conversion)
Brakes, Steering & Suspension Maintenance & Repair:
How to Change Front Brake Pads
(http://www.paulstravelpictures.com/...Front-Brake-Pads-Replacement-Guide/index.html)
Brakes, Steering & Suspension Modifications:
How to Install the TRD Lowering Springs
(http://toyotaparts.sparkstoyota.com/install/PTR07-02140inst.pdf)
How to Install the MIT Strut Bar (Post #5 in this thread)
11th gen Lowering Springs Install Notes
(https://www.toyotanation.com/forum/...-11th-gen-lowering-springs-install-notes.html)
How to Install the TRD Strut Bar(Post #6)
*How to Replace the Rear Sway Bar
(https://www.toyotanation.com/forum/...l-forum/370755-how-replace-rear-sway-bar.html)
*How to Replace the Rear Coil Springs
(https://www.toyotanation.com/forum/...-diy-how-replace-rear-shock-coil-springs.html)
*How to Replace the Front Coil Springs
(https://www.toyotanation.com/forum/...1094-how-replace-front-strut-coil-spring.html)
Exterior Maintenance & Repair:
How to Remove the Front Bumper
(https://www.toyotanation.com/forum/...14-16-corolla-front-bumper-removal-video.html)
How to Replace License Plate Light Bulbs
(http://www.paulstravelpictures.com/...late-Light-Bulbs-Replacement-Guide/index.html)
How to Replace Headlights Bulbs
(http://www.paulstravelpictures.com/...-Headlight-Bulbs-Replacement-Guide/index.html)
How to Replace Tail Light Bulbs
http://www.paulstravelpictures.com/...Tail-Light-Bulbs-Replacement-Guide/index.html
How to Replace Windshield Wiper Blades
(http://www.paulstravelpictures.com/...eld-Wiper-Blades-Replacement-Guide/index.html)
Exterior Modifications:
How to Install the Morimoto XB LED Foglights
(Post #3 & #7 in this Thread)
How to Install the Nokya LED NOK9618
(http://www.corollaforum.com/showthread.php?t=2395)
How to Install LED Foglights
How to Install the OEM Splash Guards
(https://cdn.shopify.com/s/files/1/0176/5842/files/PU060-12114-P1.pdf)
(https://www.toyotanation.com/forum/...ds-your-2014-toyota-corolla.html#post10963009)
*How to DIY a Door Handle Cup Clear Bra
(https://www.toyotanation.com/forum/...371070-diy-clear-bra-door-cup-protection.html)
*How to Install Gas Shock Hood Dampers
(https://www.toyotanation.com/forum/...r-forum/359965-diy-gas-shock-hood-damper.html)
*How to Install Backup Sensors
(https://www.toyotanation.com/forum/...p-sensor-installed-2009-corolla-s-w-pics.html)
How to Install OEM Foglights Using the CE/L Trim Factory Harness
(https://www.toyotanation.com/forum/...lla-fog-light-fiasco-solved.html#post10816009)
How to Install LED Strips as Parking Lights
(https://www.toyotanation.com/forum/...led-strips-parking-lights-very-basic-diy.html)
Swap Out Your Stock Horn
https://www.toyotanation.com/forum/...25881-diy-swap-out-your-wimpy-stock-horn.html
DIY Rear Tow Hook(Aesthetics Mod Only)
https://www.toyotanation.com/forum/...9-diy-rear-tow-hook-install.html#post11214377
Installation of a Trailer Hitch on a 2015 Toyota Corolla
Installation of Hydraulic Hood Struts
Interior Maintenance & Repair:
How to Remove the Radio and Dash Trim(CE/L Radio shown)
How to Change the Cabin Air Filter
(http://www.paulstravelpictures.com/...Cabin-Air-Filter-Replacement-Guide/index.html)
How to Remove Gear Shift Boot and E-Brake Boot
(http://www.redlinegoods.com/Corolla14install.php)
How to Replace Interior Map Light Bulbs
(http://www.paulstravelpictures.com/...-Map-Light-Bulbs-Replacement-Guide/index.html)
How to Replace Interior Dome Light Bulbs
(http://www.paulstravelpictures.com/...a-Dome-Light-Bulb-Replacment-Guide/index.html)
How to Replace Trunk Light Bulb
(http://www.paulstravelpictures.com/...Trunk-Light-Bulb-Replacement-Guide/index.html)
How to Remove the Interior Door Panels
(http://www.paulstravelpictures.com/...-Interior-Door-Panel-Removal-Guide/index.html)
Interior Modifications:
How to Install Footwell LEDs
(https://www.toyotanation.com/forum/...la-footwell-led-splice-into-cell-charger.html)
How to Install Cruise Control
(http://www.paulstravelpictures.com/...e-Control-Stalk-Installation-Guide/index.html)
How to Add a Subwoofer to Your Corolla With a Line Out Converter
(http://www.corollaforum.com/threads...-your-corolla-with-a-line-out-converter.3213/)
How to Upgrade Entune Head Units to Navigation
(https://www.toyotanation.com/forum/...ead-units-navigation-less-than-you-think.html)
How to Change the Boot Logo of Your Touchscreen Entune Radio(Post #14)
(https://www.toyotanation.com/forum/...-2016/813105-entune-audio-start-up-image.html)
3D Printed Phone Dock/Charger
(https://www.toyotanation.com/forum/...204786-diy-3d-printed-phone-dock-charger.html)
How to Install a QI Wireless Charger
(https://www.toyotanation.com/forum/...er-hidden-inside-dash-cubby.html#post10926033)
How to Install Dash Cam Video Recorder
(https://www.toyotanation.com/forum/...317073-diy-install-dash-cam.html#post10954025)
How to Paint the Interior Trim Accent Pieces
https://www.toyotanation.com/forum/...t-pieces-your-rolla-project-red-part-1-a.html
Big 3 Upgrade
https://www.toyotanation.com/forum/...016/1152193-big-3-upgrade-2015-corolla-s.html
How to Upgrade Your Front Door Speakers
https://www.toyotanation.com/forum/...de-your-front-door-speakers.html#post11034737
How to Change the Clutch Pedal Engagement
http://www.scionimforum.com/forum/engine-technical-discussion/4617-diy-fix-horrible-clutch.html
Wheels & Tires:
Winter Tire Guide
(https://www.toyotanation.com/forum/.../299314-winter-tire-tire-pressure-thread.html)
Lighting Mods
LED DRL's turn ON with headlights mod for 17+ SE XSE XLE
https://www.toyotanation.com/forum/...026-how-drl-headlights-mod-17-se-xse-xle.html
How To Install Interior and License Plate LED Bulbs
Misc Maintenance or Mods:
How to Replace Key Fob Battery
(http://www.paulstravelpictures.com/...-Key-Fob-Battery-Replacement-Guide/index.html)
Easy Fortin Remote Start Install
(https://www.toyotanation.com/forum/...30-min-corolla-remote-start-install-ever.html)
How to Change the K313 CVT Fluid
(Post #9 in this Thread)
https://www.toyotanation.com/forum/377-11th-generation-2014/1112810-bulb-reference-guide.html
Entune System Help Thread:
https://www.toyotanation.com/forum/...oftware-update-fujitsu-ten-questions-etc.html
*2ZR-FE Wiring Diagram for Greddy Emanage
https://www.toyotanation.com/forum/...e-wiring-diagram-greddy-emanage-ultimate.html
K313 CVT Information (Starts on page 60 and ends at page 71)
http://www.natef.org/NATEF/media/NA.../Toyota-ASE-IEAIT-Conference-Presentation.pdf
If a link has * in it, then it means that the specific link leads to a thread or tutorial for an older generation of Corolla. Most likely, this is either a universal part, a part for the 2ZR-FE engine, or suspension which is closely similar between these two generations.
Do It Yourself Section
Big 3 Upgrade
Wheels & Tires:
Winter Tire Guide
Lighting Mods
Important Information:
Light Bulb Sizes:https://www.toyotanation.com/forum/377-11th-generation-2014/1112810-bulb-reference-guide.html
Outside of TN Credits:
Chris Notap
Lenny Lenny
Aaron Buzali
Paul from "Paul's Travel Pictures"
DIY Auto Channel
aircmry from TMT
Donabed from CorollaForum
WWYDdotORG
RostraPC
Koby from CorollaForum
AuerAutomotive
ScioniMForum
Chris Notap
Lenny Lenny
Aaron Buzali
DIY Auto Channel
aircmry from TMT
WWYDdotORG
RostraPC
AuerAutomotive
ScioniMForum
